Home » Community » Work in progress » Yet two other D16s
Yet two other D16s [message #55781] Mon, 22 October 2012 21:53 UTC Go to next message
Shapeways Crew
Hi there,
In my attemps to make a D16, I found a D16 with a tetrahedral symmetry. Basically, take a tetrahedron (triangular pyramid), put it inside a sphere and then replace each vertex by a group of 3 circular faces, and keep one circular face where the tetrahedon had its own faces (3x4 + 4 = 16).
Another way to construct is is to take a truncated tetrahedron (4 triangular faces and 4 hexagonal faces) and then put a face for each vertex but also at the center of each hexagons.
But as you can see the faces that are at the center of the hexagons do not touch the other faces. They are what AleaKybos call "rattlers". In order to maximize the radius of the faces, you can turn a little bit each group of 3 faces corresponding to one triangle of the truncated tetrahedron, say, counter-clockwise. In this way you get some extra space to make all the faces grow a little bit. Repeat the process until you touch the (former) rattler. It is a similar operation that allows to go from the D24 to the snub-D24. That why I call this new D16 the snub-D16 with Tetrahedral symmetry.
In this image I colored the different groups of faces to better understand the process (the one nearly grey is actually orange, and the one nearly black is actualy blue, sorry for the poor rendering).
index.php?t=getfile&id=22013&private=0
The gain on the separation (that is the angle at its vertex of the cone that goes from the center of the sphere to one circular face) seems low, but actually this is a big improvement: we go from 50.48° to 51.92°
Note that none of these dice would have number on their face, so they cannot compete for the D16 Contest...
[Updated on: Tue, 23 October 2012 11:53 UTC]
Re: Yet two other D16s [message #56410 is a reply to message #55781 ] Tue, 06 November 2012 21:40 UTC Go to previous messageGo to next message
Shapeways Crew
The D16 with a tetrahedral symmetry has been numbered.
http://images1.sw-cdn.net/model/picture/674x501_745210_636743_1352237095.jpg
Sorry if the markups are odd: I did not find a was to reuse my Excel formulas to set up the markups depending on the manufacturing prices, and even worse, I did not find any way to manually set up the markup in dollars... Sad Contact me if you wish to order one.
Re: Yet two other D16s [message #57183 is a reply to message #55781 ] Tue, 20 November 2012 20:16 UTC Go to previous messageGo to next message
Magic, you can set your markup in either Dollars or Euros using the CVS Wizard on your shop page.
Shapeways Community Manager
Re: Yet two other D16s [message #57187 is a reply to message #57183 ] Tue, 20 November 2012 20:44 UTC Go to previous messageGo to next message
Shapeways Crew
Ouch! For some reasons I though it had disappeared!
But it's still here:
http://www.shapeways.com/shop/markup-csv
Great! Thank you very much!
Re: Yet two other D16s [message #58069 is a reply to message #55781 ] Wed, 05 December 2012 22:48 UTC Go to previous messageGo to next message
No worries!
Re: Yet two other D16s [message #58075 is a reply to message #58069 ] Wed, 05 December 2012 23:05 UTC Go to previous message
Shapeways Crew
I used the CSV file to make the current 15% discount in my shop.
Under Excel:
- I added a column (called "total") to add the "price" to the "markup"
- I added another colum ("total with discount") to get this value minus 15% ( ("total with discount" = 0.85*"total")
- And a third column to calculated the new markup to reach this price ("markup with discount" = "total with discount" - "price")
- Then I renamed this last column "markup", erased the original "markup" culumn and all the other columns I created and exported the CSV.
I uploaded the CSV to the Shapeways website et voilà!
Works perfectly!
Very Happy
[Updated on: Wed, 05 December 2012 23:06 UTC]
Previous Topic:Quadrifolium
Next Topic:A Voronoi Halloween
