1) Add the following things to My Elements
- Add a Filter for in Section, not in Section
- Add a Filter buyable in Material not buyable in Material
2) Easy moving between elements/groups/Selections of my elements.
3) Add Operators on this Selection (working on the whole group)
- add Material
- remove Material
- set buyable
- unset buyable
- add to section
- remove from section
- change user markup in % or in EUR/$
Use case
1) Give a discount to a group/material
I select all Items of the Group "My Jewelery"
I select all Items in silver
I reduce the markup 10%
=> results that the markup for silver in this group is reduced 10%
2)
Filter per name to "ring" (feature already exists)
add to section "Rings"
add material "Silver"
select material Silver
set markup 10 EUR
=> results that all items having ring in their name were added to the new section Rings. Additionally for all elements silver is enabled.
Then silver is selected and the markup is set to 10 EUR
(note in both case the selection of a material also applies to setting material parameters)
Sounds complicated? I think not!!!!
I think tha majority is already here. The mymodel page already should have some custom list behind.
The new selections can be added to the existing ones (material and sections resulting in drop downs so that only one button materal and section is needed). Thus adding or removing elements to the custom list.
The <list operator> can the be a selector of available operations.
What I always had in mind was that I'm able to move from element to element (after having done the selection in My models):
Seems a normal workflow to me. I do the selection in my models. Enter one model and then want to move directly to the next of this selection.
Woody64
