Home » Support » 3D Applications » Material question
Material question [message #55072] Tue, 09 October 2012 07:43 UTC Go to next message
avatar Sepia100  is currently offline Sepia100
Hi everyone,
Wich materials can I use to make a drinking cup from?
Waterproof and what can be the minimal wall tickness
Thank you in advance Very Happy
Re: Material question [message #55073 is a reply to message #55072 ] Tue, 09 October 2012 07:46 UTC Go to previous messageGo to next message
I think i know already, It got to be ceramics
Cool
Re: Material question [message #55075 is a reply to message #55073 ] Tue, 09 October 2012 07:49 UTC Go to previous messageGo to next message
Correct Smile
You can find all material details here:
http://www.shapeways.com/materials
Stijn
Re: Material question [message #55089 is a reply to message #55072 ] Tue, 09 October 2012 14:31 UTC Go to previous messageGo to next message
To add on to what you found and Virtox added, Ceramics is the only certified food safe material. This is because the glazing process is a certified food safe process. So if you us another material, it would be up to you to use a food safe process to make it work.
Re: Material question [message #55158 is a reply to message #55072 ] Wed, 10 October 2012 21:01 UTC Go to previous messageGo to next message
Okay I Uploaded my model! Do you think 2,5 mm wall tickness also be strong enough?
have any experience with it?
Tnx
Re: Material question [message #55177 is a reply to message #55158 ] Thu, 11 October 2012 09:01 UTC Go to previous messageGo to next message
The minimum wall thickness for ceramics is 3 mm or more depending on the size:
Min Wall Supported:
If bounding box x+y+z is 120-200mm: 3mm
x+y+z is 200-300mm, min wall should be 4mm
x+y+z is 300-400mm, min wall should be 6mm
And if you want a hollow cavity in a model there needs to be a hole for the "support" material to get out:
Min Escape Hole:
10-15mm diameter
You can read all the details here:
http://www.shapeways.com/materials/ceramics-design-guideline s
Re: Material question [message #55222 is a reply to message #55177 ] Thu, 11 October 2012 19:51 UTC Go to previous messageGo to next message
Thanks for your help didn't notice it before I moddeld a hole in it.
All of sudden it's way more expensive almost twice as much, and the hole is not showing up in all the pictures
Is this normal?
Re: Material question [message #55229 is a reply to message #55222 ] Thu, 11 October 2012 20:21 UTC Go to previous message
Ceramics is special in that it is priced per surface area, not per volume. (Suggests that
the glazing is an order of magnitude more expensive than the clay).
So adding holes can actually make your model more expensive in ceramics.
Previous Topic:lost wax casting
Next Topic:Which Application to Use?
