Home » Community » General Discussion » Small Batch Manufacturing
Small Batch Manufacturing [message #55048] Mon, 08 October 2012 22:33 UTC Go to next message
avatar LaunchFarm  is currently offline LaunchFarm
So you've gotten your Shapeways plastic prototype back and it works perfectly. Now you are thinking about producing a small batch (under 500 units) of this small plastic product to sell online. How do you begin the actual search for an inventor-focused manufacturer to explore pricing and help with next steps on the heels of your shapeways model? Any thoughts? Does Shapeways partner with anyone to facilitate this process?
Any info will be appreciated.
Re: Small Batch Manufacturing [message #55074 is a reply to message #55048 ] Tue, 09 October 2012 07:47 UTC Go to previous messageGo to next message
Under 500 units, you'll need it to be a mighty profitable item. 3DP may be your best option: hand casting is very expensive if you don't do it yourself, while injection molding starts to make sense about 10,000 units. Short-run plastics manufacturing is a vale of tears and broken dreams...good luck.
-Bathsheba
http://bathsheba.com
Re: Small Batch Manufacturing [message #55084 is a reply to message #55074 ] Tue, 09 October 2012 12:57 UTC Go to previous messageGo to next message
The first thing you have the think about is whether your piece can be copied using a two part mould. If it can there are various way which it could be made relatively cheaply. These would include vacuum casting in resin, casting in pewter and lost wax casting. If your piece needs a more complicated mould then either the mould costs will go up or you piece will have to broken down into multiple parts and assembled. Again this will increase the costs.
Be selective when you choose a company to batch produce your pieces. In general I would suggest that the prices charged by those companies producing for the hobby/models trades will be very much lower than those charged by those whose main interest is in producing prototypes for engineering or product development.
Bill Bedford
Re: Small Batch Manufacturing [message #55172 is a reply to message #55074 ] Thu, 11 October 2012 04:10 UTC Go to previous messageGo to next message
Bathsheba wrote on Tue, 09 October 2012 07:47
Bathsheba, I'm curious about this. Would you mind explaining why? I have a customer that was thinking to go this route, and would like to give him good advice if short run plastic runs are a bad idea.
Have you had any experience with Protolabs - either good or bad? They offer Rapid prototyping and short run injection molding.
-Marcus
Re: Small Batch Manufacturing [message #55174 is a reply to message #55172 ] Thu, 11 October 2012 06:17 UTC Go to previous messageGo to next message
Well, good and bad are very situational: I'm certainly not saying it can't work.
The overall trouble with short-run plastics manufacturing is simply that people don't expect to pay a lot for small plastic things. Unless you've got a really sharp niche, you're competing with people doing runs of 100K from injection molds in China, and they set the expectation for pricing. How much "should" a 2" plastic thing retail for? A trip to the dollar store tells you, $1, $2 at most.
That the other responder in this thread suggested pewter is telling...the thingis that once you're into hand casting -- paying someone to make molds and then pour, demold and chase each individual part -- you might as well use a better material than plastic, because it's going to be just as much work and you can charge more for the result. (This assumes that your part is readily castable, which if you didn't specifically design it to be is not immediately likely.)
I don't have specific experience with Protolabs. I agree on "be selective": get lots of quotes but save your money for the very best fit.
I'd also say, research your target method intensively using the Internets, and do your best to make your design manufacturable -- castable if you want to cast it, paintable if you want to paint it, etc. -- before sending it out. If these guys sense that you don't understand their process and won't make your design sympathetic to it, they'll quote high to get rid of you.
-Bathsheba
Re: Small Batch Manufacturing [message #55184 is a reply to message #55174 ] Thu, 11 October 2012 12:14 UTC Go to previous messageGo to next message
Thanks for the explanation, Bathsheba - it makes a lot of sense!
Back to the OP's questions - no, Shapeways doesn't work with vendors to mass produce products after 3D printing. You may find some very useful info by browsing Kickstarter projects (especially the "Updates"). Here's one to get you started - The Glif. About halfway down the page, the creators of the project put together a video of their search for finding an injection molding company after their successful campaign.
-Marcus
Re: Small Batch Manufacturing [message #55185 is a reply to message #55174 ] Thu, 11 October 2012 12:23 UTC Go to previous message
avatar glehn  is currently offline glehn
Bathsheba wrote on Thu, 11 October 2012 06:17
Short-run injection is widely used in the scale modeling industry by smaller companies that make very unusual subjects mostly overlooked by the larger manufacturers (who do in fact inject their products by the thousands in China). As Bathsheba said, this is a very good example of a niche where this can work.
So, I think it all really depends on what kind of product you are planning to make and what market you want to reach. For 500 units I would look into either resin casting, short-run injection or even 3D printing and selling it through Shapeways.
Good luck,
Glehn
Previous Topic:Frosted Ultra Detail Silicon Mold
Next Topic:Why isn't "polished" black SF available?
