| How small can holes be printed? [message #54404] Sat, 22 September 2012 22:59 UTC |
I have searched but can't find the answer to this: how small can holes be printed in ultra detail? I would like to have printed an object, wall size 6 mm by 2.6 mm with a number of holes going through the wall that are .37 mm in diameter. Can this be done? If not, how large could they be printed? Cleaning powder from the holes is not a problem, that can be done with a small drill bit.
| Re: How small can holes be printed? [message #54405 is a reply to message #54404 ] Sun, 23 September 2012 00:59 UTC |
I hunted up this choice bit, http://www.shapeways.com/materials/frosted-detail-design-gui delines Seems a 2mm diameter hole is advised for best results.
[Updated on: Sun, 23 September 2012 01:03 UTC] Have any questions regarding Blender, and need fast answers, you are always welcome at the IRC Server Freenode, channel #blender. As a bonus, several there have experience in modelling for 3D prints.
| Re: How small can holes be printed? [message #54406 is a reply to message #54405 ] Sun, 23 September 2012 01:28 UTC |
Thanks for the info. I think I will submit a design that has .37 mm holes and see what happens. If this can be printed, it would save me an enormous amount of time machining this item.
| Re: How small can holes be printed? [message #54407 is a reply to message #54406 ] Sun, 23 September 2012 02:26 UTC |
2mm is the minimum "drain hole".. you can make much smaller holes than that.
Take a look at the second picture on this model: http://shpws.me/3QAx
The pulley on the end of the arm has a 0.30 mm hole thru it.
In the closeup photo you can see a human hair threaded thru the hole.
| Re: How small can holes be printed? [message #54408 is a reply to message #54407 ] Sun, 23 September 2012 02:40 UTC |
Wow! That's incredible. Just what I wanted to know. Thanks!
| Re: How small can holes be printed? [message #54430 is a reply to message #54428 ] Sun, 23 September 2012 23:19 UTC |
Thanks again for the great info. SS has saved me a ton of work.
| Re: How small can holes be printed? [message #56223 is a reply to message #54430 ] Fri, 02 November 2012 11:00 UTC |
This is a follow up about the parts that were printed. The holes were not printed, however, I designed a countersink on the outside of the part and I was able to use it tto he hand drill the holes which saved me the time of making a drilling jig and hand drilling them. Also, it was much more accurate. Here's some pics, the first shows the part drilled with a .013" bit and threaded with a .09" monofilament nylon line. The second, it a holding jig, strung with the line and the third, with a tire. This is a wire wheel for a 1/24th scale model. Thanks for the help.
Attachment: DSCN9310.JPG
(Size: 667.82KB, Downloaded 26 time(s))
Attachment: DSCN9315.JPG
(Size: 627.17KB, Downloaded 28 time(s))
Attachment: DSCN9318.JPG
(Size: 805.61KB, Downloaded 22 time(s))
