| Nearly right is not enough. [message #54245] Wed, 19 September 2012 12:56 UTC |
Even if the end result is correct again should the subtotals to be correct.
Attachment: Temp.jpg
(Size: 12.62KB, Downloaded 164 time(s))
| Re: Nearly right is not enough. [message #54299 is a reply to message #54245 ] Thu, 20 September 2012 16:50 UTC |
Hi norm,
The subtotal is just for display for you. It is not a figure we use in accounting, we just display it on the invoice to make the invoice easy to read.
In accounting, we NEVER actually subtotal the amounts as this can lead to rounding errors.
We round once, at the end, so as not to overcharge you for the currency conversion.
If you think it would be clearer, I am happy to post the exact numbers too - but since it is your data, I am more than happy to do it via PM rather than on the public forum.
I hope this explains it!
Best,
Natalia
[Updated on: Thu, 20 September 2012 18:46 UTC] Community Manager | Shapeways
| Re: Nearly right is not enough. [message #54333 is a reply to message #54329 ] Fri, 21 September 2012 12:26 UTC |
| norm24 wrote on Fri, 21 September 2012 09:48 |
The invoice must always vote.
Detlev
Just to help avoid any confusion. I suspect that "Vote" here is a mistranslation of the German "Stimmen", which can mean either "be correct" or "vote", depending on context. "Be correct" would be the proper translation here.
Greetings
Dragoman
| Re: Nearly right is not enough. [message #54446 is a reply to message #54333 ] Mon, 24 September 2012 14:34 UTC |
Norm24, I PM'd you further details.
Best,
Natalia
