Home » Support » 3D Design » Sizing help -Medical research purposes- New member-first timer
Sizing help -Medical research purposes- New member-first timer [message #53878] Tue, 11 September 2012 16:11 UTC Go to next message
avatar Calaka  is currently offline Calaka
Good morning
We are stuck at sizing. I´m working in zbrush but I do need this 3D print to be a very accurate and exact size since it is for medical research purposes.
I exported a obj. file from Osirix (from a DICOM file) to MeshLab where I deleted some unwanted artifacts and parts. Then exported a new obj. file to zbrush were I did the modeling. Once the work is done, I try to prepare the file using the 3D printer option in zbrush but the size it shows there is too big (mm) for its real life size purpose. So I haven´t uploaded the model because I need to get the exact size to be printed.
In the picture you can see the skull taken from DICOM file with Osirix. As notice I worked in zbrush where I modeled a part on the side. I imported the file from Osirix into zbrush to make it fit and it does as shown in the image. But the thing is how do I print this part (not the whole skull, only the modeled part) in real life sizes so it can fit the real scanned skull?
Please could you help me out I don´t know if I have been clear enough.
Thanks in advance
index.php?t=getfile&id=20362&private=0
  • Attachment: Views.jpg
    (Size: 316.97KB, Downloaded 103 time(s))
[Updated on: Tue, 11 September 2012 16:12 UTC]
Re: Sizing help -Medical research purposes- New member-first timer [message #53893 is a reply to message #53878 ] Tue, 11 September 2012 18:20 UTC Go to previous messageGo to next message
Open your file in http://www.netfabb.com/basic.php
There you can measure, scale and repair if necessary.
jacantdesign@gmail.com
Re: Sizing help -Medical research purposes- New member-first timer [message #53966 is a reply to message #53893 ] Thu, 13 September 2012 02:39 UTC Go to previous message
Determine the unit size that zbrush exports as a STL if you do not want a colored material.
Import into netfabb which will give you the bounding box dimensions. If you scanned a cube whose dimensions were 12" x12" x12" for example, after importing into nettfabb, the bounding box dimensions were 12mm x 12mm x 12mm, you would then scale the object by a factor of 25.4 to get it to print to the correct size, then export the new object as a STL, upload to Shapeways.
When ever you have a problem always make sure to put a link to a file you need help with. That helps loads. What might be driving you crazy, many here can fix after a few minutes, and get you set up. PM me for any help.Smile
Previous Topic:First timer, trying to make my design hollow
Next Topic:First time - How to get my adobe illustrator logo into 3D?
