Home » Support » 3D Printing » Texture Map size for Full Color Sandstone?
Texture Map size for Full Color Sandstone? [message #53873] Tue, 11 September 2012 14:51 UTC Go to next message
avatar MikeP  is currently offline MikeP
Is there an optimum size for textures to use with full color Sandstone?
I had a print done last month and I used a 24bit 1000x1000 image. The results were good but would a higher resolution be better or (as I suspect) does the printer resize the image before using it?
If the printer does resize the image I'd like to know the resolution so I supply it in the correct size myself.
Re: Texture Map size for Full Color Sandstone? [message #53938 is a reply to message #53873 ] Wed, 12 September 2012 17:29 UTC Go to previous messageGo to next message
... nothing from Shapeways?
Is my question not clear?
Re: Texture Map size for Full Color Sandstone? [message #61412 is a reply to message #53938 ] Tue, 05 February 2013 19:13 UTC Go to previous messageGo to next message
avatar clearmenser  is currently offline clearmenser
http://www.shapeways.com/tutorials/exporting_to_vrml_and_x3d _for_color_printing
Re: Texture Map size for Full Color Sandstone? [message #61429 is a reply to message #61412 ] Tue, 05 February 2013 22:23 UTC Go to previous message
Amazing! Finally. Thanks!
"we recommend you keep the total resolution of your texture maps below 2048x2048 pixels."
Previous Topic:Dimensions
Next Topic:minimum size for a good polished?
