| Texture Map size for Full Color Sandstone? [message #53873] Tue, 11 September 2012 14:51 UTC |
Is there an optimum size for textures to use with full color Sandstone?
I had a print done last month and I used a 24bit 1000x1000 image. The results were good but would a higher resolution be better or (as I suspect) does the printer resize the image before using it?
If the printer does resize the image I'd like to know the resolution so I supply it in the correct size myself.
| Re: Texture Map size for Full Color Sandstone? [message #53938 is a reply to message #53873 ] Wed, 12 September 2012 17:29 UTC |
... nothing from Shapeways?
Is my question not clear?
| Re: Texture Map size for Full Color Sandstone? [message #61429 is a reply to message #61412 ] Tue, 05 February 2013 22:23 UTC |
Amazing! Finally. Thanks!
"we recommend you keep the total resolution of your texture maps below 2048x2048 pixels."
