Hi, I am planning an order of quite a large object in silver that needs to be as dimensionally accurate as possible. I am wondering how to take account of the expected shrinkage of the object from casting: Should i scale up the model by about 2% (which is the deviation measured from previous printed objects), or will the shapeways operators make the necessary changes to the model to ensure it's final dimensional accuracy? I really want to get this right first time due to ithe protibitive cost. The model is around 28x28x109mm
2% shrinkage seems a lot for the casting process. I suggest that it is much less than that if there is any at all.
Here's some info on the silver material. https://www.shapeways.com/materials/silver-design-guidelines. Good luck with getting it printed.
Just an update in case this infomation is useful to anyone; I went ahead and ordered the above model in silver with a 2% increase in scale and this factor turned out to be pretty much perfect. All internal dimensions remained within telorances and the threads were all very good. Here are a few pictures of the finished light: Thanks Shapeways.
