Home » Community » 3D modeler needed » Ring Design
Ring Design [message #53690] Thu, 06 September 2012 16:31 UTC Go to next message
avatar bloodletting284  is currently offline bloodletting284
I was looking to have a design for a ring made. Basically like the link included below.
Gear Ring
Any help would be greatly appreciated.
Re: Ring Design [message #53691 is a reply to message #53690 ] Thu, 06 September 2012 16:57 UTC Go to previous messageGo to next message
That's a patented item - not just the design, but the workings, as in 'an invention' - good luck to anyone who takes this on.
Re: Ring Design [message #53720 is a reply to message #53691 ] Thu, 06 September 2012 23:01 UTC Go to previous messageGo to next message
avatar TechyBen  is currently offline TechyBen
Sad really as it's a very simple design (too simple for a patent?).
Not sure if the tolerances allow for it to be printed. A design just with cogs as decoration (not functional/moving) would be ok I guess. But the best idea is to come up with an idea that has not been done before. Smile
Re: Ring Design [message #53721 is a reply to message #53720 ] Thu, 06 September 2012 23:05 UTC Go to previous messageGo to next message
It is not just a design, but a mechanism utilising a silimar geared setup to a planet gear set.
And even if your Googlefu is mediocre, you will find court cases bought by the patent holders against copiers.
Re: Ring Design [message #53723 is a reply to message #53721 ] Thu, 06 September 2012 23:17 UTC Go to previous messageGo to next message
I'd either make it myself (IE, personal use), so that's what the OP needs to do. Or make it different. As you said, it's a planet mechanism (how this is patentable, I've no idea, orbital gears exist else where). PS, they are over 2000 years old. http://en.wikipedia.org/wiki/Epicyclic_gearing
So make one without them.
[Updated on: Thu, 06 September 2012 23:23 UTC]
Re: Ring Design [message #53811 is a reply to message #53723 ] Sun, 09 September 2012 16:40 UTC Go to previous messageGo to next message
This was available awhile back on Grabcad
Geared Ring - Kinematic Rev8- Drilled
If you Google it the links are dead.
index.php?t=getfile&id=20300&private=0
  • Attachment: gear ring.png
    (Size: 46.80KB, Downloaded 95 time(s))
jacantdesign@gmail.com
Re: Ring Design [message #53812 is a reply to message #53811 ] Sun, 09 September 2012 17:54 UTC Go to previous message
Probably because it's put up publicly. AFAIK there is nothing stopping you from making one for and by yourself, just not viable by or for anyone else.
Try for a different design, you never know, you might make something better!
Previous Topic:Plastic Army Men
Next Topic:Help with some 1/100 scale projects
