| about thin walls [message #5008] Wed, 24 June 2009 12:18 UTC |
Hello....
I have a little "problem" with wall thickness....
how do you calculate the "limit" of printability of a model ?
I know there's 1mm min for "détail" and 0.7 for WSF, but... sometimes I don't know in witch case we can pass through this.
Here is an example that will be clearer :
If I want to print a "cone" of 3cmx3cmx3cm.... the end of the cone is going smaller and smaller... and it pass always under the 1mm limit !
other example :
Here is an Ogre..... (picture below)
It's a 3.9cm figurine.... it has passed succesfully the "upload" checks...
but the staples of the shoes are only 0.5mm thick.
Will the model be "unprintable" or "printable" ?
Finaly a last question : is the limit fixed by the printers or is this a limit you've decided to assure resistance ?
Galladur
