| Non-orientable Bridge [message #53092] Fri, 24 August 2012 16:32 UTC |
I am trying to 3D print a bridge which is over 1 metre long in two parts. On the part 1 when i put it through netfabb it seems all fine but it won't upload to shapeways. On the second part there seems to be a problem with non-oreintable surfaces and won't upload either.
All the parts are non-manifold and I am having trouble fixing the model to upload. Not sure if it is a problem with the intersecting shells. Any advice would be much appreciated.
Attachment: part1a.jpg
(Size: 286.26KB, Downloaded 46 time(s))
| Re: Non-orientable Bridge [message #53119 is a reply to message #53092 ] Sat, 25 August 2012 12:16 UTC |
No Message Body
Attachment: bridge1.stl
(Size: 9.20MB, Downloaded 19 time(s))
[Updated on: Sat, 25 August 2012 12:26 UTC]
| Re: Non-orientable Bridge [message #53129 is a reply to message #53119 ] Sat, 25 August 2012 18:08 UTC |
As can be seen by the image your model has surfaces with no thickness. You will to give these parts at least the minimum wall thickness, plus there are extra rules for 'large' parts which will increase the minimum wall thickness.
Attachment: bridge.png
(Size: 105.91KB, Downloaded 231 time(s))
jacantdesign@gmail.com
| Re: Non-orientable Bridge [message #53130 is a reply to message #53129 ] Sat, 25 August 2012 19:08 UTC |
The whole part is meant to be printed as one solid piece with nothing hollowed. Does each surface need to be edited to 1mm even if the object is solid?
| Re: Non-orientable Bridge [message #53131 is a reply to message #53130 ] Sat, 25 August 2012 19:33 UTC |
Your model is actually made up of 4196 shells with 4148 holes, plus there are faces pointing the wrong way (inverted normals), which gives the impression that your model is hollow. I have tried to repair your model, as can be seen. The model now has 286 shells and 40 holes. The thickness is now showing correct. I can not repair it any further. You could try uploading the file to http://cloud.netfabb.com/
Attachment: bridge1.png
(Size: 355.38KB, Downloaded 209 time(s))
| Re: Non-orientable Bridge [message #53134 is a reply to message #53131 ] Sat, 25 August 2012 21:53 UTC |
I get the same result when i try to repair it, however it is more of the problem that when i try to export the part it creates more errors. Is there a way of preventing these non manifold surfaces being created when exported? To do the automatic repair with a lower tolerance creates too much deformed geometry.
| Re: Non-orientable Bridge [message #53135 is a reply to message #53134 ] Sat, 25 August 2012 23:13 UTC |
You could try Viscam Mesh.
http://www.marcam.de/cms/viscam-mesh.84.en.html
It is a very good program available on a 30 day trial. I had a copy but my time ran out, it is very expensive to buy.
What program did you use ro create your model?
I noticed that most of the faults were on the sides between the rails, maybe if you do these again? Is there a way in your software to 'boolean' the parts together?
| Re: Non-orientable Bridge [message #53161 is a reply to message #53135 ] Sun, 26 August 2012 14:26 UTC |
Thanks for the advice. I remodelled those side parts in rhino and put it through viscam mesh. There are no more errors and it passes the checks through netfabb however, it still refuses to upload. I'm not sure what the other parameters are in the upload checks which the model is not meeting as it doesn't mention anything specific.
(Size: 9.22MB, Downloaded 15 time(s))
