Modeler needed for 35mm dia pendant
Modeler needed for 35mm dia pendant [message #52759] Fri, 17 August 2012 13:40 UTC
avatar mtnman  is currently offline mtnman
I am new to this site and would like to turn a 2D jpg into a 3D pendant (imagine that). Very Happy
Diameter should be around 35mm. The thickness would be about the size of two stacked coins. The Mayan calendar piece thickness would about 1/8" and raised above the lower level sun rays.
Original Design Mock-up
index.php?t=getfile&id=19722&private=0
Black and white versions I've tried using here (I have one model based on the last image below)
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion6.jpg
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion5.jpg
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion2.jpg
Alternative approach (no Mayan 3D print, I would secure a mayan calendar coin to inset into the piece)
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion4.jpg
Material (metals)
Ideally this would be two tone - the sun rays silver, the Mayan calendar gold, and the rim between the two bronze.
Let me know if you would like more info or another image. Thanks!
Previous Topic:Modeler
Next Topic:Cat model
