Home » Support » 3D Applications » Still having sizing issues
Still having sizing issues [message #52409] Thu, 09 August 2012 07:14 UTC Go to next message
avatar Helkat  is currently offline Helkat
Hello everyone, thanks for reading my post.
i am still having sizing issues when exporting from 3ds max 11 to shapeways. I have tried cm, mm, and inches. I am making sure my upload selection matches the selection I am working in. I have changed both Customize->Units Setup and System Unit Setup. I also tried downloading the calculator, and it won't work. I have tried using both OBJ and STL files, still no luck.
Does anyone have any other ideas I could try? Thanks in advance.
Re: Still having sizing issues [message #52410 is a reply to message #52409 ] Thu, 09 August 2012 07:17 UTC Go to previous messageGo to next message
Can you describe your problem in more detail?
What size are you intending?
What does the calculator say?
What does the site say?
Cheers!
Re: Still having sizing issues [message #52411 is a reply to message #52410 ] Thu, 09 August 2012 07:46 UTC Go to previous messageGo to next message
When I try to run the calculator I get a MAXScript FileIn Exception error that says:
-- Syntax error: at keyword parameter, expected name
-- In line: HyperLink txMaterialInfo mainLink address:m
For Units setup, I currently have US Standard Decimal inches selected, and for System Unit Scale, I have 1 Unit = 1 inches.
I am trying to make a basic bangle, to sort of just get started and get my bearings. I want it to have an inner diameter of 2.75 inch, an outer of 3.5, and a height of 0.75.
In the parameters for the tube, which is the primitive I'm using, I have entered these measurements. However, when I go to utilities, and press measure, the x dimension is 6.894, the Y is 7, and the z is 0.75.
After uploading the STL to the site, (and selecting inches), I get..... in: 6.9 w x 7 d x 0.7 h
Re: Still having sizing issues [message #52412 is a reply to message #52411 ] Thu, 09 August 2012 07:51 UTC Go to previous messageGo to next message
Hmm, will check on the error for the calculator.
As for the size, for a tube you need radia which are the diameter/2.0.
[Updated on: Thu, 09 August 2012 07:51 UTC]
Re: Still having sizing issues [message #52413 is a reply to message #52411 ] Thu, 09 August 2012 07:52 UTC Go to previous messageGo to next message
Also, for that calculator error, it brings up the code and jumps to line 1127.
Re: Still having sizing issues [message #52414 is a reply to message #52412 ] Thu, 09 August 2012 07:53 UTC Go to previous messageGo to next message
virtox wrote on Thu, 09 August 2012 07:51
Derp. I was wondering why the height seemed to stay consistent, but the rest did not....
Embarassed
Re: Still having sizing issues [message #52415 is a reply to message #52413 ] Thu, 09 August 2012 08:01 UTC Go to previous messageGo to next message
I am puzzled as to why the error would occur, and maxscript debugging is not always helpful..
Could you try to change line 1140 (i think)
HyperLink txtMaterialInfo mainLink address:mainLink color:(color 127 127 255) hovercolor:(color 255 0 0) visitedcolor:(color 0 0 192) align:#left offset:[10,0]
with this:
HyperLink txtMaterialInfo "" address:"" color:(color 127 127 255) hovercolor:(color 255 0 0) visitedcolor:(color 0 0 192) align:#left offset:[10,0]
And see what that does for the error?
Re: Still having sizing issues [message #52416 is a reply to message #52415 ] Thu, 09 August 2012 08:08 UTC Go to previous message
line 1140 looks like notes. It's line 1127. And that seemed to fix it. :>
I feel so silly for the radius/diameter thing. I reuploaded, and that fixed the issue. -_- I have been trying to figure this out for an entire week. I think I've had my blonde moment for the remainder of the year. Embarassed
Thank you so much for your help!!! Very Happy
Previous Topic:"Design could not be validated" when uploading colour model
Next Topic:Viscam mesh
