| How to determine real-life size [message #52372] Wed, 08 August 2012 14:19 UTC |
I want to upload and create a bracelet using shapeways, and I already have a autocad file for it. However, I don't know how to make sure that, when it is printed, it is the right size to actually fit on someone's wrist. Could anyone tell me how I can see and set the scale factor in my model? Much appreciated.
| Re: How to determine real-life size [message #52373 is a reply to message #52372 ] Wed, 08 August 2012 14:25 UTC |
Make sure the bounding box of the uploaded file matches what it should be. Then in your cad software you could print it out on a 2D printer 1:1 and see what size it would be.
| Re: How to determine real-life size [message #52374 is a reply to message #52373 ] Wed, 08 August 2012 14:39 UTC |
so shapeways always uses the 1 unit to 1 inch (or 1 meter/mm) scale?
| Re: How to determine real-life size [message #52375 is a reply to message #52374 ] Wed, 08 August 2012 14:44 UTC |
I depends on how you export the file, and the file type. Some file types only deal in certain units. Other file types don't specify a unit, so Shapeways will ask you which units to use when you upload the file.
| Re: How to determine real-life size [message #52377 is a reply to message #52375 ] Wed, 08 August 2012 14:56 UTC |
The program I'm using does do a 1:1 scale, thanks for your help.
| Re: How to determine real-life size [message #52382 is a reply to message #52377 ] Wed, 08 August 2012 19:59 UTC |
You could just download NetFabb Studio Basic for free and measure the model to ensure it is the correct size before uploading (if it's the wrong size you can use NetFabb to rescale the model file to the right size too)
And as Mike says, filetype and measurement units come into the mix too - the safest bet is to create in units as inches or mm for whatever software you use, check the measurements in NetFabb and then upload the model as the units you see works in NetFabb.
| Re: How to determine real-life size [message #52388 is a reply to message #52385 ] Wed, 08 August 2012 20:19 UTC |
A length of string & tape measure along with netfabb works too
How many times over the last couple of years have we seen 'sizing' questions?
