Home » Support » 3D Design » Dual extrusion
Dual extrusion [message #52123] Tue, 31 July 2012 02:27 UTC Go to next message
avatar ComesToLife  is currently offline ComesToLife
I am not new to modeling, but new to printing. I understand what the method of dual extrusion means, but I am not clear how the printer recognizes this process. How should the model be done in order for it to work?
Thanks.
Custom 3D Artist
www.ComesToLife.com
Re: Dual extrusion [message #52126 is a reply to message #52123 ] Tue, 31 July 2012 03:23 UTC Go to previous messageGo to next message
Dual Extrusion doesn't apply to any of the Shapeways printers. The closest thing they have that comes to it is the process used by Full Color Sandstone, and that's more like a BubbleJet printer, rather than dual extruders.
Re: Dual extrusion [message #52138 is a reply to message #52126 ] Tue, 31 July 2012 10:15 UTC Go to previous messageGo to next message
yes. I know that... I read through their material info last week when I joined... but I have a client now asking for it and I am just curious of how that works.
I am told it should be two different stl files(in different color), but I am not clear if they can intersect and still print fine or they should be not touching each other, but still be separate files. And when it comes to different color, does that mean different shaders will work or color should be applied to vertices...
Custom 3D Artist
www.ComesToLife.com
Re: Dual extrusion [message #52172 is a reply to message #52138 ] Tue, 31 July 2012 21:48 UTC Go to previous message
I understand they should be in separate STL files. The separate files can have geometry that touches, but it can't overlap. The coloring is done in your modeling package before exporting to STL just so you can tell the separate parts from each other.
Here is more discussion on the matter (near the bottom of page): https://groups.google.com/forum/#!topic/makerbot/XkjVnsyCsMM
-Marcus
Previous Topic:How to fix zero wall thickness
Next Topic:3D design first time - Doing it right?
