| Inventory management [message #52121] Tue, 31 July 2012 02:10 UTC |
Did I miss a memo about inventory management? It looks like the all-markups-on-one-page page is gone. I find the setup for editing markups within each model very awkward to use.
I miss being able to see the markups for a model in all materials at the same time. Also being able to see markups for many models at the same time.
Worse, I can't push a single markup amount to all materials with one click, which makes this process take 20 times longer.
I think it would be great if something like the one-screen method came back. Or if the link has just been moved, can someone tell me where it is?
-Bathsheba
http://bathsheba.com
| Re: Inventory management [message #52125 is a reply to message #52121 ] Tue, 31 July 2012 03:21 UTC |
I find the CSV markup management very much easier to use.
| Re: Inventory management [message #52273 is a reply to message #52121 ] Fri, 03 August 2012 19:43 UTC |
Hi Guys,
I've asked Brad about this, we'll get back to you shortly!
Best,
Natalia
Community Manager | Shapeways
| Re: Inventory management [message #54079 is a reply to message #52273 ] Sat, 15 September 2012 14:00 UTC |
I find the old markup system was easier to use.
with the CSV file, the numbers have the ' in front of the numbers so I can't add the sum up to see what the total price is. I want to set the final price to say, $139 and the cost is $99.34. Now I have to calculate my markup in an external calculator to see what the final price will be.
| Re: Inventory management [message #54082 is a reply to message #54079 ] Sat, 15 September 2012 14:33 UTC |
I'm a bit lost when you say that there is a single quote in front of the numbers.
I just re-downloaded my CSV file, and there are DOUBLE quotes around all the fields, but Excel 2010 strips those out when it loads the file.
Are you using Excel, Google Docs, or something else?
| Re: Inventory management [message #54191 is a reply to message #54083 ] Tue, 18 September 2012 01:42 UTC |
I have a hack that I use to set my markup. I can apply %, % up to $0.99, or flat rate... but it requires you to go into each item individually.
For me, I only add one item every month or so, so it's not that bad... would you guys be interested in the hack?
