Home » Community » Instructions » HO scale narrow gauge 25 foot cars
HO scale narrow gauge 25 foot cars [message #52026] Sat, 28 July 2012 13:32 UTC Go to next message
avatar pinddle  is currently offline pinddle
I'm planning on producing some of the rolling stock of the Ohio River & Western Railway, a 3 foot gauge railroad.They are suitable for both HOn30 and HOn3, there will be versions for both gauges.They are designed to sit on my trucks, available for both gauges.
The first one available is a flatcar, with or without stakes.
Here are the two versions with stakes,fitted with the appropriate trucks and couplers.
index.php?t=getfile&id=18983&private=0
To weight the model I glued some strips of lead between the sills.I used EZ line to make the truss rods.
index.php?t=getfile&id=18984&private=0
This is the HOn30 version, painted and fitted with micro-trains 1015 couplers.
index.php?t=getfile&id=18985&private=0
There are two small supports for the handbrake wheel at one end.They need to be drilled out to accommodate whatever you use, I used some 0.4mm dia. brass rod.The finished model:
index.php?t=getfile&id=18986&private=0
Coming next,gondolas.
  • Attachment: flatcar-1.jpg
    (Size: 83.21KB, Downloaded 494 time(s))
  • Attachment: flatcar-2.jpg
    (Size: 103.75KB, Downloaded 487 time(s))
  • Attachment: flatcar-3.jpg
    (Size: 99.97KB, Downloaded 480 time(s))
  • Attachment: flatcar-4.jpg
    (Size: 95.87KB, Downloaded 489 time(s))
Re: HO scale narrow gauge 25 foot cars [message #52462 is a reply to message #52026 ] Fri, 10 August 2012 14:17 UTC Go to previous messageGo to next message
I have updated the design, as part of the queen-post was too thin and fell foul of the thin walls rule.At least one order was rejected because of this.
The new version 'should' be ok.Apologies if you have been affected by this.There is a degree of uncertainty about detail parts and minimum wall thickness.
[Updated on: Fri, 10 August 2012 14:17 UTC]
Re: HO scale narrow gauge 25 foot cars [message #52677 is a reply to message #52462 ] Wed, 15 August 2012 21:42 UTC Go to previous messageGo to next message
The gondolas are now available.The same build method applies to them.
I'll post photos of a finished one later, when I've finished it!
Re: HO scale narrow gauge 25 foot cars [message #53082 is a reply to message #52677 ] Fri, 24 August 2012 14:42 UTC Go to previous messageGo to next message
Some photos of finished gondolas.
HOn30 4 plank:
index.php?t=getfile&id=19901&private=0
HOn30 2 plank:
index.php?t=getfile&id=19900&private=0
HOn3 2 plank:
index.php?t=getfile&id=19899&private=0
The underside is the same as the flatcar.
Coming next, boxcars.
Re: HO scale narrow gauge 25 foot cars [message #54429 is a reply to message #53082 ] Sun, 23 September 2012 22:42 UTC Go to previous messageGo to next message
A pipe gondola is now available.This is based on the 4 plank gondola, with the end planks removed.The handbrake wheel is moved to the side to make room for a long load.The supports for the handbrake assembly need to be drilled out, as indicated by the arrows below.
index.php?t=getfile&id=20821&private=0
The finished model.
index.php?t=getfile&id=20822&private=0
  • Attachment: pipe4.jpg
    (Size: 79.76KB, Downloaded 428 time(s))
  • Attachment: pipe3.jpg
    (Size: 73.28KB, Downloaded 436 time(s))
Re: HO scale narrow gauge 25 foot cars [message #54468 is a reply to message #54429 ] Mon, 24 September 2012 22:44 UTC Go to previous messageGo to next message
Boxcars.
My first design is with integral roof and roofwalk.The floor is a separate part, attached to the body by 4 bits of sprue.Take care to not damage the stirrups when separating them.
The floor has 4 notches in it near the ends for the truss rods.I used a loop made from EZ Line, about 5 inches long.
The handbrake assembly passes through the platform and lower support at one end (arrowed).
Weight can be added onto the top of the floor before final assembly.
index.php?t=getfile&id=20827&private=0
Assembled:
index.php?t=getfile&id=20828&private=0
I was not entirely happy with the test prints.The layering (stepping) was quite evident on the roof.This effect will of course vary with print orientation.
By painting and sanding I was able to achieve a smooth finish.To avoid this I've designed a version without a roof.Plastic card (styrene sheet) is used instead for the roof.You will need a piece 27x89 mm, scored down the middle.This also works out cheaper.The floor is integral with the body in this version, with holes for the truss rods.The roofwalk is attached to the body by some bits of sprue.
I have not test printed this design yet, but in theory it should work ok.
[Updated on: Mon, 24 September 2012 22:48 UTC]
Re: HO scale narrow gauge 25 foot cars [message #58843 is a reply to message #54468 ] Tue, 18 December 2012 21:46 UTC Go to previous messageGo to next message
I've added another gondola, with a body only 1 plank high.Assembly method is the same as the other gondolas.
index.php?t=getfile&id=24531&private=0
The test print suffered broken stirrups, which I replaced with metal rod.To try to prevent this happening again I have added some support material, which will need to be removed during assembly.
index.php?t=getfile&id=24532&private=0
Re: HO scale narrow gauge 25 foot cars [message #58844 is a reply to message #58843 ] Tue, 18 December 2012 22:03 UTC Go to previous messageGo to next message
Maintenance of Way boxcars.
These are modified from ordinary boxcars.They have four windows added.Type A retains the original sliding doors.Type B has replaced this with new inset doors.
These pictures of the raw prints show how the roofwalk comes attached to the body.This must be removed before assembly.
index.php?t=getfile&id=24533&private=0
index.php?t=getfile&id=24534&private=0
Assembly method is the same as the other boxcars, except you will need some glazing material for the windows.
Finished models:
index.php?t=getfile&id=24535&private=0
index.php?t=getfile&id=24536&private=0
Re: HO scale narrow gauge 25 foot cars [message #62347 is a reply to message #58844 ] Mon, 18 February 2013 22:54 UTC Go to previous messageGo to next message
I've now added a caboose at last.HOn3 and HOn30 versions, same body, different chassis.
The body and chassis are linked together for printing by some small linking pieces.Cut through these to separate them, inside you will find the roofwalks.
There are no queenposts, but there are guides and holes for the truss-rods.
index.php?t=getfile&id=27532&private=0
index.php?t=getfile&id=27533&private=0
index.php?t=getfile&id=27534&private=0
I've not got very far with this yet, the ladder is just a suggestion for the end.It needs lots of handrails and a handbrake wheel.
Note, on this prototype model the chassis was slightly too short, hence the cut-outs in the body sides.This has been corrected now.
See the next post for more useful info, the chassis is the same.
  • Attachment: cab_3.JPG
    (Size: 147.74KB, Downloaded 208 time(s))
  • Attachment: cab_4.JPG
    (Size: 154.23KB, Downloaded 204 time(s))
  • Attachment: cab_2.JPG
    (Size: 164.23KB, Downloaded 206 time(s))
[Updated on: Tue, 19 March 2013 19:12 UTC]
Re: HO scale narrow gauge 25 foot cars [message #64443 is a reply to message #62347 ] Tue, 19 March 2013 19:09 UTC Go to previous message
Baggage Car (developed from the caboose).
The model is printed with the body and chassis joined by some fine links.
index.php?t=getfile&id=29298&private=0
Cut and remove these links and clean up the remaining parts.
index.php?t=getfile&id=29299&private=0
There are 4 small holes in the floor to help with the truss-rods.
Here I have used E Z line, the ends are glued to the floor.
index.php?t=getfile&id=29300&private=0
index.php?t=getfile&id=29301&private=0
There are mounting points at each end for a brake wheel.
index.php?t=getfile&id=29302&private=0
The body clips onto the chassis.
  • Attachment: bg_3_1.JPG
    (Size: 147.06KB, Downloaded 149 time(s))
  • Attachment: bg_3_2.JPG
    (Size: 324.10KB, Downloaded 148 time(s))
  • Attachment: bg_3_3.JPG
    (Size: 296.48KB, Downloaded 148 time(s))
  • Attachment: bg_3_4.JPG
    (Size: 310.88KB, Downloaded 147 time(s))
  • Attachment: bg_3_5.JPG
    (Size: 310.83KB, Downloaded 159 time(s))
Previous Topic:Fractured Tetrahedron Sticker Template
Next Topic:Materials Infographic
