Home » Support » 3D Design » Multi-color
Multi-color [message #51625] Fri, 20 July 2012 19:50 UTC Go to next message
avatar njcadman  is currently offline njcadman
Can a design with multiple parts be printed in different colors or materials for each part?
Re: Multi-color [message #51627 is a reply to message #51625 ] Fri, 20 July 2012 20:01 UTC Go to previous messageGo to next message
Yes it can, but only in Full Color Sandstone.
Re: Multi-color [message #51630 is a reply to message #51627 ] Fri, 20 July 2012 20:31 UTC Go to previous messageGo to next message
I use Rhino3D.
Can I print mult-color from Rhino?
Also, if I used the same color and materials, can I print multiple parts in 1 file?
Re: Multi-color [message #52068 is a reply to message #51630 ] Mon, 30 July 2012 07:34 UTC Go to previous messageGo to next message
Rhino doesn't allow you to export colour in models for printing. You will have to create a UV map in another programme, I use Blender.
V
www.dotsan.com
Re: Multi-color [message #52104 is a reply to message #52068 ] Mon, 30 July 2012 18:32 UTC Go to previous messageGo to next message
Rhino does allow exporting in VRML. Will this work?
Also, I have 3DSMAX 2009. Can I use this to export color?
Re: Multi-color [message #52124 is a reply to message #52104 ] Tue, 31 July 2012 03:06 UTC Go to previous messageGo to next message
For uv maps, sure. Vertex paint is a no. It will not recognize different material colors on the mesh as actual color differences for printing purposes . Thus why you have to zip the UV texture file into the vrml file, so the Shapeways printer can find the the texture applied to the UV mapped model..
1. Add a material to the mesh
2. UV unwrap the mesh(Several techniques you can use to unwrap
3, Apply image to the material(Use UV mapping)
4. Zip the export with the image you used
Mesh lab(free) will show just about what Shapeways receives when you up load the model. But since if you opened up the image on your comp that has the file, no need to zip anything, until its uploaded to Shapeways
Re: Multi-color [message #52131 is a reply to message #52124 ] Tue, 31 July 2012 07:23 UTC Go to previous messageGo to next message
Yes 3D Max will let you create a UV map and export as vrml.
V
www.dotsan.com
Re: Multi-color [message #52141 is a reply to message #52124 ] Tue, 31 July 2012 11:43 UTC Go to previous message
Fredd wrote on Tue, 31 July 2012 03:06
Vertex paint is a no. It will not recognize different material colors on the mesh as actual color differences for printing purposes.
I am not so sure about the vertex color ?
In the past I have succesfully uploaded vertex color models, and the site rendered them correctly, although I have not printed yet them.
But at the time Shapeways acknowledged this option.
I am currently testing some new vertex color models, but they they seem to choke the upload renderer. Probably size/complexity, will poll CS about it.
In the mean time, are there any good tools that convert from vertex color to UV maps? Seems like a difficult process..
Previous Topic:How to fix zero wall thickness
Next Topic:Dual extrusion
