Home » Support » 3D Printing » PA2200 White, Strong & Flexible
PA2200 White, Strong & Flexible [message #51292] Fri, 13 July 2012 19:58 UTC Go to next message
avatar crosbkev  is currently offline crosbkev
Trying to locate material data sheet for PA2200.
I see eos lists 5 different types of PA2200 as follows:
Balance 1.0
Performance 1.0
Speed 1.0
Top Quality 1.0
Top Speed 1.0
Which type of PA2200 is being used as White, Strong & Flexible?
Re: PA2200 White, Strong & Flexible [message #51294 is a reply to message #51292 ] Fri, 13 July 2012 20:08 UTC Go to previous messageGo to next message
You mean this one?
http://www.shapeways.com/topics/udesign/materials/white_stro ng_flexible/pa2200_material_data_sheet_12_08_en__.pdf
Bill Bedford
Re: PA2200 White, Strong & Flexible [message #51295 is a reply to message #51294 ] Fri, 13 July 2012 20:22 UTC Go to previous messageGo to next message
I noticed that eos no longer lists just the PA2200 on thier material data centre, but rather have split it into the above mentioned types. Just wondering which one is now being used.
Re: PA2200 White, Strong & Flexible [message #51308 is a reply to message #51295 ] Sat, 14 July 2012 06:16 UTC Go to previous messageGo to next message
avatar VeryWetPaint  is currently offline VeryWetPaint
The various grades refer to the machine's settings. It's all the same material, polyamide 12 "nylon."
Shapeways uses 0.15 mm layers (ie: 150 m) which corresponds to EOS's PA 2200 Speed 1.0 grade.
Re: PA2200 White, Strong & Flexible [message #51347 is a reply to message #51308 ] Sun, 15 July 2012 00:37 UTC Go to previous messageGo to next message
So the PDF is outdated?
Anyway, the old values seem to be around (new) Balance and Performance (layers 120-100). It could explain why old products had less layering issues.
Re: PA2200 White, Strong & Flexible [message #51478 is a reply to message #51347 ] Tue, 17 July 2012 17:29 UTC Go to previous messageGo to next message
stannum wrote on Sun, 15 July 2012 00:37
What "old values" do you mean? Shapeways used the 0.15mm at least back to 2010, and probably longer than that.
Re: PA2200 White, Strong & Flexible [message #51504 is a reply to message #51478 ] Wed, 18 July 2012 00:23 UTC Go to previous message
The ones in the PDF BillBedford linked.
Previous Topic:Silver printed ring questions - shrinkage, etc.
Next Topic:Question about detail features & Materials
