PA2200 White, Strong & Flexible
Discussion in 'Materials' started by 95180_deleted, Jul 13, 2012.
  1. 95180_deleted
    95180_deleted Member
    Trying to locate material data sheet for PA2200.
    I see eos lists 5 different types of PA2200 as follows:
    Balance 1.0
    Performance 1.0
    Speed 1.0
    Top Quality 1.0
    Top Speed 1.0
    Which type of PA2200 is being used as White, Strong & Flexible?
  2. BillBedford
    BillBedford Member
  3. 95180_deleted
    I noticed that eos no longer lists just the PA2200 on thier material data centre, but rather have split it into the above mentioned types. Just wondering which one is now being used.
  4. VeryWetPaint
    VeryWetPaint Member
    The various grades refer to the machine's settings. It's all the same material, polyamide 12 "nylon."
    Shapeways uses 0.15 mm layers (ie: 150 µm) which corresponds to EOS's PA 2200 Speed 1.0 grade.
  5. stannum
    stannum Well-Known Member
    So the PDF is outdated?
    Anyway, the old values seem to be around (new) Balance and Performance (layers 120-100). It could explain why old products had less layering issues.
  6. VeryWetPaint
    VeryWetPaint Member
    What "old values" do you mean? Shapeways used the 0.15mm at least back to 2010, and probably longer than that.
  7. stannum
    The ones in the PDF BillBedford linked.
