Home » Community » Work in progress » Scoobie Bracelets
Scoobie Bracelets [message #51121] Tue, 10 July 2012 21:17 UTC Go to next message
OK, they actually arrived, but I prefer keeping them as work in progress, I will explain why later.
The Scoobie Bracelet and the Twisted Scoobie Bracelet are two bracelets made like lanyards.
The regular one is made of 4 strings forming actually 4 loops.
http://images1.sw-cdn.net/model/picture/640x476_613842_488488_1341943320.jpg
For the twisted one, I twisted one end of a quarter of turn before joining both ends. It is made of one single string and thus one loop (similar to a moebius shape).
http://images1.sw-cdn.net/model/picture/640x476_613844_488494_1341943395.jpg
Their internal circumference is 20 cm.
Unfortunately, they are not flexible as I expected. So your fist has to go through a circle of 20 cm of circumference if you want to wear them. I'll try to make thinner strings (currently they are 1.5x3mm) to get a better flexibility (hopefully). That's why they are still tagged "work in progress".
Check the video.
Do you like them?
Re: Scoobie Bracelets [message #51140 is a reply to message #51121 ] Wed, 11 July 2012 12:45 UTC Go to previous messageGo to next message
I do like them, what about trying elasto?
Re: Scoobie Bracelets [message #51330 is a reply to message #51140 ] Sat, 14 July 2012 19:03 UTC Go to previous message
Yes, you are right. It should work with Elasto Plastic. And the thickness should be enough.
But I am not really convinced by the black color...
I will perhaps give it a try: I have still 6 days left to decide Smile
[EDIT] Arghhh: the clearance should be 1.5mm so unfortunately this design won't work with Elasto Plastic (only 0.5mm of clearance)
[Updated on: Sat, 14 July 2012 19:08 UTC]
Previous Topic:Bird Skull Pendant
Next Topic:Jor-El 1/6 Scale Crystal Mask Superman
