Home » Support » 3D Design » wall thickness on heads
icon8.gif  wall thickness on heads [message #51068] Mon, 09 July 2012 14:09 UTC Go to next message
avatar gcptkilla  is currently offline gcptkilla
Dear all ,
i am creating heads with a big hole at the neck to save money.
So far so good.
I am spending the most of the time to get the min. wall thickness of 2mm. (sandstone 3d printing)
Attached please find a screenshot.
there you will see that it differs sometimes from 6mm to 0.9mm. Embarassed
Do you have any idea to make the min. wall thickness exactly and easier?
I am working with zbrush and cinema 4d,
I hope you could help me.
regards
Re: wall thickness on heads [message #51070 is a reply to message #51068 ] Mon, 09 July 2012 14:37 UTC Go to previous messageGo to next message
Best way I know of is to use Blender, read through this, and it will tell you how to do it in Blender, creating an easy unified wall thickness. http://www.shapeways.com/forum/index.php?t=msg&th=9932&a mp;start=0&
Re: wall thickness on heads [message #51074 is a reply to message #51070 ] Mon, 09 July 2012 15:33 UTC Go to previous messageGo to next message
Thanks for your fast help.
But I have problems with intersecting walls at the ears, nose and eyes.
Is there a possibility that I import the head with hole and incorrect wall thickness and then blender moves only the inner wall away from outer wall?
thanks
Re: wall thickness on heads [message #51075 is a reply to message #51068 ] Mon, 09 July 2012 15:42 UTC Go to previous messageGo to next message
That's pretty much the limit of my Blender knowledge, so hopefully someone else can jump in and help you. There may even be a zbrush or cinema 4d solution, but I don't have any knowledge of using them.
Re: wall thickness on heads [message #51091 is a reply to message #51068 ] Mon, 09 July 2012 20:57 UTC Go to previous messageGo to next message
Use MeshLab - See http://www.shapeways.com/forum/index.php?t=rview&th=9324 &goto=47799#msg_47799
[Updated on: Mon, 09 July 2012 20:59 UTC]
Re: wall thickness on heads [message #51514 is a reply to message #51091 ] Wed, 18 July 2012 11:09 UTC Go to previous message
Get your self a copy of VisCAM Mesh. 30 days usable test version. It will automatically hollow out your model to the thickness you want. http://www.marcam.de/cms/viscam-mesh.84.en.html
jacantdesign@gmail.com
Previous Topic:Wallthickness Issues
Next Topic:How to fix zero wall thickness
