| Problem with sizes [message #50926] Fri, 06 July 2012 16:50 UTC |
Hi, whenever i upload a project to Shapways the size is always wrong.. i am using 3ds max 2010 and the height of my object is 4cm. I export it in STL format and when i look at "My Models" on Shapeways it is .4 cm... has anybody run into this and what could be the problem/what am i doing wrong?
| Re: Problem with sizes [message #50927 is a reply to message #50926 ] Fri, 06 July 2012 17:09 UTC |
So you're working in cm, and the upload offers mm or meters. Seeing your seeing a drop of one decimal point, I'm assuming you upload as mm. You'll need to export as mm and upload as mm. Or you can scale up your model by 10.
| Re: Problem with sizes [message #50928 is a reply to message #50926 ] Fri, 06 July 2012 17:10 UTC |
Hi!
This depends on the settings both in max and at upload time.
In max there is Customize->Units Setup
Here you can choose how units are displayed.
I have this set at mm.
Up top is a button "System Unit Setup"
If you click that it will show you what the units max shows are in reality.
I have this at 1 unit is 1mm.
At upload time also then choose "mm" scale and you should be set
Stijn
[Updated on: Fri, 06 July 2012 17:10 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
| Re: Problem with sizes [message #50930 is a reply to message #50928 ] Fri, 06 July 2012 17:13 UTC |
Ooooh i see, thanks! Im exporting cm and uploading as mm.
And thank you Virtox i think i have the units set up as 1 unit -> 1 cm even when im exporting as mm...
okay thanks guys, hopefully this solves my issue.
| Re: Problem with sizes [message #50933 is a reply to message #50931 ] Fri, 06 July 2012 17:22 UTC |
Thaaaaat did it. They are uploading properly now. Thanks guys!
| Re: Problem with sizes [message #50934 is a reply to message #50926 ] Fri, 06 July 2012 17:39 UTC |
Glad we could get you up and running!
| Re: Problem with sizes [message #51794 is a reply to message #50928 ] Tue, 24 July 2012 19:24 UTC |
Hello!
I am having the same issue, however I have set both of these options to CM, (tried inch and mm too), also have tried exporting as stl and obj, and I still can't get the uploaded size to be correct. Any ideas? I am using 3ds max 2011. Thanks.
