| Plastic clip [message #50533] Thu, 28 June 2012 14:30 UTC |
I have virtual drawings and renderings of the item. I will need it in several dimensions but please advise me on how much you will charge to make a readable file for the printing process.
Dimensions:
Width 2.40 in
Depth 0.47 in
Height .5
Patrick
Attachment: Picture 1.jpg
(Size: 149.30KB, Downloaded 96 time(s))
[Updated on: Thu, 28 June 2012 14:31 UTC] Keep on Rockin'!
| Re: Plastic clip [message #50540 is a reply to message #50533 ] Thu, 28 June 2012 17:07 UTC |
Hi Patrick,
If you have a 3D model file of the clip, send it on over in a PM or to paul[at]stop4stuff[dot]com. Chances are, from your image, it will just need converting to a format accepted by Shapeways - if not, I'll give you a price for the job.
| Re: Plastic clip [message #50567 is a reply to message #50533 ] Fri, 29 June 2012 01:47 UTC |
$150
Inspire through Design, Create Solutions, Deliver on Promise
| Re: Plastic clip [message #50648 is a reply to message #50533 ] Sat, 30 June 2012 16:12 UTC |
Hello Patrick,
If you could send the files to past3dt@gmail.com I will be able to convert the file so that it is acceptable for shapeways to print as well as review the file for printing tolerances. This will allow for your first attempt to be printed correctly. If the file can not be converted or some tolerances are not met then I will model the plastic clip for $100.00.
Thank you and have a nice day
