Help needed with a simple Model
Help needed with a simple Model [message #9921] Sat, 13 February 2010 17:03 UTC Go to next message
avatar xicemanx  is currently offline xicemanx
Hi there.
I wanted to create a simple passepartouts-like inner bezel for a small picture frame, that holds my mobile phone. anyhow.... i already tried a lot of things and i cant rid of the non manifold errors after uploading it on shapeways. if i convert the google sketchup or dae file to another format like .stl I even get a new error every time i upload it.
maybe one of you can take a look at it and find the problem(s). i would really appreciate it.
here's the .dae file exported by google sketchup.
thanks
Re: Help needed with a simple Model [message #9933 is a reply to message #9921 ] Sat, 13 February 2010 22:56 UTC Go to previous messageGo to next message
avatar Anbar  is currently offline Anbar
that file is a bit of a mess...
theres an object canted at 45 degrees across the back of the "holder" - no idea if thats intended or not - do you have an image of what it is supposed to look like?
Re: Help needed with a simple Model [message #9954 is a reply to message #9933 ] Mon, 15 February 2010 09:42 UTC Go to previous messageGo to next message
thank you so much for taking a look at it anbar.
the object at the back of the holder was supposed to be a kind of pocket for a stand for the frame, but it's not necessary to be there.
as written before this thing is the inner plate of a picture frame bezel. i attached 3 images of what it's supposed to look like. i just added a bigger bezel in two of the images attached to make it clear what this should look like.
thank you again for helping me out with this.
  • Attachment: picframe.zip
    (Size: 281.45KB, Downloaded 141 time(s))
Re: Help needed with a simple Model [message #10076 is a reply to message #9921 ] Sat, 20 February 2010 20:40 UTC Go to previous messageGo to next message
avatar rhadidian  is currently offline rhadidian
try this
  • Attachment: frame01.stl
    (Size: 36.90KB, Downloaded 211 time(s))
Re: Help needed with a simple Model [message #10270 is a reply to message #10076 ] Sat, 27 February 2010 14:52 UTC Go to previous message
rhadidian wrote on Sat, 20 February 2010 20:40
try this
thank you so much, it looks great and all manifold errors are gone. you used inches as metric system while editing it, right?
what application did you use to fix the manifold stuff?
thanks again,
iceman
Previous Topic:SKULL JEWELS
Next Topic:Need logo artwork done
