Shapeways says my model is too small, but it's being uploaded at a tiny scale [SOLVED]
Shapeways says my model is too small, but it's being uploaded at a tiny scale [SOLVED] [message #93846] Sun, 13 July 2014 17:07 UTC Go to next message
avatar Vulwulf  is currently offline Vulwulf
Hi, I'm relatively new to shapeways, I made some blank Space Marine chests to use as a scale to make other parts and for some reason Shapeways says they are 0.6cm wide even for a set of 10 sprued together while the model is a full 15cm wide.
In fact I made a scale mistake and made them twice the size of a miniature (doh) but it still comes out as too small at 6mm wide.
I make stupid mistakes, but I can't see what would be making this so much smaller, I set my units to millimetres in my 3d modeller (3ds Max) and the same when uploading, any ideas?
Again, these were to check the scale so I could make some extra bits etc, I don't intend to repeatedy make/sell these.
Edit: Hope it's ok to put this in general, I couldn't figure out where else to put it.
[Updated on: Mon, 14 July 2014 15:34 UTC]
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #93848 is a reply to message #93846 ] Sun, 13 July 2014 17:48 UTC Go to previous messageGo to next message
That mismatch is suspiciously close to the 2.54 (or .39) of metric/imperial conversion. Check if there is a separate entry for export units in 3dsmax (or just
rescale your model in netfabb studio basic before uploading)
Usually this kind of question gets posted in either of "Work in progress", "3d printing" or "3d design", but moderators will move threads to the appropriate forum if necessary.
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #93915 is a reply to message #93848 ] Mon, 14 July 2014 13:59 UTC Go to previous messageGo to next message
Thank you, I'll take a look into that and post the results if any.
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #93922 is a reply to message #93848 ] Mon, 14 July 2014 15:33 UTC Go to previous messageGo to next message
Result! (In case anyone comes across this thread with the same issue).
So I couldn't work out why it was so small, it exported correctly so I can only figure that 3ds Max can't make things at a mm scale accurately, in future perhaps I should make things in Generic Units then upload at mm scale...
Using Netfabb basic was the key to changing the scale accurately since it can do it uniformly and with mm/percent scales, the only issue is I needed to measure the original which is potentially inaccurate, thank you for the suggestion.
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #93956 is a reply to message #93922 ] Tue, 15 July 2014 07:40 UTC Go to previous messageGo to next message
Good to know you've been able to solve it :)
For the record, these are my settings in 3ds max, never had any scaling issues!
index.php?t=getfile&id=64989&private=0
  • Attachment: fyi.JPG
    (Size: 113.24KB, Downloaded 168 time(s))
Customer Service Coordinator
Shapeways
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #93987 is a reply to message #93956 ] Tue, 15 July 2014 12:12 UTC Go to previous messageGo to next message
Bingo, I forgot about the System Units Setup button (been over a year since I last 3D modelled) The scale was set to 1 = 1.0 inches, as mkroeker mentioned it was close to the metric/imperial conversion, thanks for showing me that screenshot Mitchell, I wouldn't have noticed that (It's only the biggest button in the box, after all...)
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #93991 is a reply to message #93987 ] Tue, 15 July 2014 12:37 UTC Go to previous messageGo to next message
Thanks Mitchell for the screenshot. Think you can talk your colleague Duann into adding it to his tutorial ? :-)
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #94025 is a reply to message #93991 ] Wed, 16 July 2014 07:01 UTC Go to previous messageGo to next message
Which tutorial are you referring to http://www.mtasa-us.org/q1/emoticons/emoticon_blush.gif
I'll be happy to ask him to add it :)
It's funny, the picture I showed above I created at home.
In the office I have this picture on my desktop as I use it regularly to show customers.
The System Unit Setup is the part most people are missing.
So they create a model in millimeter, but the system still calculates it as for example inches in the background.
http://i.imgur.com/DIPBHXx.png
Shapeways
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #94026 is a reply to message #94025 ] Wed, 16 July 2014 07:11 UTC Go to previous messageGo to next message
MitchellJetten wrote on Wed, 16 July 2014 07:01
Must be as hard to find as the system units menu you showed us - title is 3D Modeling in 3d Studio Max for Shapeways (first entry under the heading "Using your favorite 3d software with shapeways" in the tutorials section).
Re: Shapeways says my model is too small, but it's being uploaded at a tiny scale. [message #94027 is a reply to message #94026 ] Wed, 16 July 2014 07:44 UTC Go to previous message
Hmm that one is really outdated :P
I should find some time to write a new tutorial :)
Shapeways
Previous Topic:2D to 3D design smaller than 30mm in width
Next Topic:Is it possible to cut costs by combining multiple smaller models?
