Home » Support » 3D Design »
Sizing in Maya
Sizing in Maya [message #93478] Sun, 06 July 2014 00:53 UTC Go to next message
avatar Quadraxis86  is currently offline Quadraxis86
I'm making a small hairclip in Maya and I'd like the dimensions to be around 3cm by 3cm by 0.6cm. I was using the distance tool within Maya to check the dimensions but it seems to upload to a smaller scale in Shapeway. I've checked my units in the settings in Maya which are in Millimeters, but when my model is around 30mm in Maya, it sizes down to about 20mm in Shapeway. Does anyone know a reliable method for measuring in Maya?
Re: Sizing in Maya [message #93503 is a reply to message #93478 ] Sun, 06 July 2014 18:01 UTC Go to previous messageGo to next message
avatar samfleming  is currently offline samfleming
Have you confirmed that your measurement is broken in maya - and the sizing is just not being lost in translation when moving between files/formats or the shapeways services? LIkely your measurements are accurate within maya, its just getting butchered in conversion along the way.
Try exporting the file to another app to verify the size. You could export an STL and import that in a free app like openscad for instance.
You might also try running your file through a cleanup tool such as http://netfabb.azurewebsites.net before uploading it to shapeways.
Sam Fleming
http://www.thelostpiece.com
$40 Flat Fee 3D Design Service
Re: Sizing in Maya [message #93507 is a reply to message #93478 ] Sun, 06 July 2014 18:48 UTC Go to previous messageGo to next message
Size errors with exports from Maya have been reported several times, though it is normally off by a factor of 10 apparently. (Suggesting that Maya may be using centimeters as its export units no matter what). Get netfabb studio basic (freeware) from netfabb.com to check and resize your models before uploading - this is as close to what shapeways uses internally as you can get.
Re: Sizing in Maya [message #93519 is a reply to message #93507 ] Mon, 07 July 2014 03:10 UTC Go to previous messageGo to next message
Netfabb works great for sizing, but now its made a change of its own to my model. I have absolutely no clue how to fix it. I can upload a picture if needed. It's deleted a few of the necessary faces from a support piece, leaving a hole in the model.
Re: Sizing in Maya [message #93525 is a reply to message #93519 ] Mon, 07 July 2014 07:52 UTC Go to previous messageGo to next message
Probably needs a picture to see what really happened, especially if you think that netfabb modified your model on its own , without you selecting "repair" first. How much did you have to resize your model (thinking if it is possible that the missing faces were not attached to the rest of the model, so were not
resized with it and are now sitting somewhere inside, or in another corner of the world coordinate system) ?
Re: Sizing in Maya [message #93580 is a reply to message #93525 ] Tue, 08 July 2014 00:00 UTC Go to previous messageGo to next message
Here's two pics of the model, one in Maya and one in Netfabb. I exported the Maya file to an OBJ into Netfabb. The broken section looks the exact same before and after the repair feature in Netfabb. I have tried exporting it into 3ds Max, but I still get the same results when putting it into Shapeways.
  • Attachment: Maya.PNG
    (Size: 238.50KB, Downloaded 36 time(s))
  • Attachment: Capture.PNG
    (Size: 135.83KB, Downloaded 38 time(s))
Re: Sizing in Maya [message #93589 is a reply to message #93580 ] Tue, 08 July 2014 07:34 UTC Go to previous message
Can you get Maya to display surface normals for that patch (or even just wireframe to see if it is really a single closed surface or a crisscross of overlapping polygons that is glossed over by shading) ? Or try a different output format - stl for example - in case there is a problem with the obj export
function.
Previous Topic:Someone got some clean medium plugs template ?
Next Topic:Casting, Escape Holes, and Internal Volumes.
