Size Tolerances for 3D Model Components
Size Tolerances for 3D Model Components [message #93031] Mon, 30 June 2014 13:46 UTC Go to next message
avatar Aaro_Arts  is currently offline Aaro_Arts
Hello there.
This is my first time here so I hope I've posted this query in the correct place.
I'm building a 3D model with individual components that fit together once printed.
I'm unsure of the best way to describe it, so I have included this image for illustration purposes:
http://i.stack.imgur.com/3UiQT.png
As you can see, this cuboid has a cap that slots into it once it's 3D printed.
My question is, will they fit together if the edges are the same size (in this case 6mm and 24mm), or do I need to make the cap slightly smaller? if so, by how much? After all I don't want it to be loose, but I also need it to fit nicely.
I figure it may be fine if a bit of force is used as it's being printed in plastic here at Shapeways.
Thanks guys.
Re: Size Tolerances for 3D Model Components [message #93061 is a reply to message #93031 ] Mon, 30 June 2014 17:41 UTC Go to previous messageGo to next message
What plastic material are you planning on having the model printed in?
In my experience, Shapeways Frosted Ultra Detail is about the best tolerance fit (same dimensions) you can get, for the Strong & Flexible varieties, I find that maybe 0.1-0.2mm less on the lid (insert) portion side of things is ok, but not perfect.
Re: Size Tolerances for 3D Model Components [message #93078 is a reply to message #93061 ] Mon, 30 June 2014 19:26 UTC Go to previous messageGo to next message
Hey,
Thanks for taking the time to post a comment. It's much appreciated.
I plan to print it in the white/black strong and flexible plastic.
I have since adjusted the sizes to allow a tolerance of 0.1mm. I hope that's enough :)
If not, I may have to try the detailed plastic.
Thanks again.
Re: Size Tolerances for 3D Model Components [message #93090 is a reply to message #93078 ] Mon, 30 June 2014 21:09 UTC Go to previous message
Knowledge Expert
Real life difference in measurements for WSF it is 0.20 mm error.
[Updated on: Mon, 30 June 2014 21:09 UTC]
numarul7 jewelry and design
Previous Topic:How close can individual pieces be in one Obj?
Next Topic:3D Modeling Help and Tips
