Uploads not showing up in "My Models" - wait? re-upload?
Uploads not showing up in "My Models" - wait? re-upload? [message #91364] Thu, 05 June 2014 19:16 UTC Go to next message
avatar Iacov  is currently offline Iacov
hey !
sorry if this happens to be a frequently asked question, but I couldn't find an answer via search
i have uploaded a model - the preview was displayed correctly and some material checks were done...but the check didn't finish, even after almost an hour (I experienced this occassionally...even waiting a day won't finish the material check...) so i deleted the model (which showed up under "My Models") and reuploaded the model (with a renamed file - just in case)
this time no preview picture was rendered, no size/volume information given, and of course no material checks - plus the model is not showing up under "My Models" for almost 15 minutes.
I tell myself "give it time"...in the meantime I wanted to upload another model...but the same happened to this (wholy different) model, too: it is not showing up under "My Models"
what should I do?
what does your experience tell you?
will the models eventually show up?
or should i count them as "lost in the ether"?
should i simply re-upload them again? or should i at least re-name the file?
thanks for your advice!
best regards
edit:
now they showed up, but material check doesn't finish /proceed
[Updated on: Thu, 05 June 2014 19:35 UTC]
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #91365 is a reply to message #91364 ] Thu, 05 June 2014 19:37 UTC Go to previous messageGo to next message
We are currently having some issues with uploads. They are being worked on as we type.
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #91366 is a reply to message #91365 ] Thu, 05 June 2014 19:39 UTC Go to previous messageGo to next message
thank you very much!
should I delete the models or can I keep them uploaded and the material check will finish automatically?
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #91371 is a reply to message #91366 ] Thu, 05 June 2014 20:02 UTC Go to previous messageGo to next message
Once the clog is found and removed, all items in the que will be processed. So just leave it as is, and once we fix it, all will be good.
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #91380 is a reply to message #91371 ] Thu, 05 June 2014 23:48 UTC Go to previous messageGo to next message
Knowledge Expert
Still happening.
index.php?t=getfile&id=61208&private=0
Happiness again!
index.php?t=getfile&id=61197&private=0
  • Attachment: Vv5KxRa.gif
    (Size: 924.10KB, Downloaded 116 time(s))
[Updated on: Thu, 05 June 2014 23:51 UTC]
numarul7 jewelry and design
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #91503 is a reply to message #91380 ] Sat, 07 June 2014 08:44 UTC Go to previous messageGo to next message
the bug is still in effect, as I tried today
uploads work, but no material checks proceed
edit: the above is not true anymore, just got an email, that my model is ready to order, and indeed: the model has gone true material checks
[Updated on: Sat, 07 June 2014 08:53 UTC]
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #92025 is a reply to message #91503 ] Mon, 16 June 2014 17:17 UTC Go to previous messageGo to next message
avatar Strangefate  is currently offline Strangefate
Checks go through but the model preview stays blank on any new uploaded models and the thin walls model view stays always empty too :(
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #92049 is a reply to message #91364 ] Mon, 16 June 2014 19:59 UTC Go to previous messageGo to next message
I haven't had any issues today. How long ago did you upload? Larger models take longer to process, so may just need a little more time?
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #92054 is a reply to message #92049 ] Mon, 16 June 2014 20:11 UTC Go to previous messageGo to next message
Hey,
I've been uploading and updating models intermittently lately and the issue has been there for a week or 2 now as far as I can remember.
Last model I updated was 4 hours ago, the one before that was yesterday... or the day before and they both still don't show a preview.
The models have an average of 100-300k triangles, but I've tried just uploading small parts of them to troubleshoot the issue, with no luck.
Any model I upload or update end up with blank 3D previews. The customer 3D preview and default shapeways render show up, but not the wall thickness and initial 3d preview... which are a lot better when you want to make sure the model is being read correctly.
I can still order the models just fine, it's just somewhat scary when you're used to double checking things after upload.
One of the models I uploaded yesterday or the day before is: https://www.shapeways.com/model/1642764/balljoint-tests.html ?li=aeTabs
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #92058 is a reply to message #92054 ] Mon, 16 June 2014 20:30 UTC Go to previous messageGo to next message
Anything changed in your browser settings ? Remember you need WebGL support for the newfangled preview and the thickness checks...
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #92062 is a reply to message #92058 ] Mon, 16 June 2014 20:37 UTC Go to previous messageGo to next message
nope, nothing changed... I do use the same browser (Chrome) at work and home, but the problem happens in both.
A few days ago I tried re- uploading a model 6 times I think it was, and it eventually showed the preview and thickness check 3d preview, so it didn't seem an issue on my end.
I'll see if I can look into the WebGL and make sure all is well there just in case.
Re: Uploads not showing up in "My Models" - wait? re-upload? [message #92064 is a reply to message #92062 ] Mon, 16 June 2014 20:48 UTC Go to previous message
mkroeker - Turns out the WebGL was issue thanks!
Don't know what broke it, and Chrome was telling me WebGL was running okay but after a forced browser update it works again!
Previous Topic:Color lost when fixing thin walls
Next Topic:Tried to post suggestion
