| Stainless Steel Ring Assortment [message #8501] Tue, 22 December 2009 19:51 UTC |
Hi, here's a selection of rings that arrived form Shapeways:today.
I really love the results:
Ring 1: Lego Ring - There are a few lines / artefacts form the scintering process.
It's a really solid piece of jewellery.
The piece is approx 0.2mm smaller than the original 3d model's dimensions - there maybe some shrinkage in the process.
As a result lego brick fits on the studs, just, but it's a tight fit.
Ring 2: Diamond "Bling" Ring - this came out really well. The 3d model was made with lots of smooth, curved edges and the result looks very well finished. I will try polishing this up with a dremel.
Ring 3/4: Fork Ring. I really pushed the minimum wall thickness for this ring. Most of it is 1.2 mm in thickness.
The tines of the fork are smaller still. As a result it is quite lumpy and may be too thin to polish up. But Now I know exactly what the lower tolerances are for Stainless Steel. The print of the same model in White Strong & Flexible material was perfect in every detail!
Thanks and Merry Christmas to the team at Shapeways for a great first print. I hope to do more very soon.
[Updated on: Tue, 22 December 2009 19:52 UTC]
| Re: Stainless Steel Ring Assortment [message #8536 is a reply to message #8501 ] Thu, 24 December 2009 10:46 UTC |
Lego, always cool
Nice designs and amassing how thin your fork is! Only the the star on the end is missing in rvs, probably polished off.
Anyway, good job man, keep up the good work!
Mathijs
