Rotating Wheels
Rotating Wheels [message #84590] Sat, 08 February 2014 22:36 UTC Go to next message
avatar Richy  is currently offline Richy
Shapeways Crew
Has anyone printed a rotating wheel on an axle that didn't require assembly after it was printed?
I'm Working on a toy-car-sized Rock Crawler Buggy that I hope will print in one piece with rotating wheels and compressible springs! I have 1mm clearances between the rims and the axles, but I'm still a little worried about how it will come out.
index.php?t=getfile&id=51475&private=0
index.php?t=getfile&id=51476&private=0
index.php?t=getfile&id=51477&private=0
index.php?t=getfile&id=51481&private=0
  • Attachment: Crawler4.png
    (Size: 16.55KB, Downloaded 358 time(s))
  • Attachment: Crawler1.png
    (Size: 300.53KB, Downloaded 358 time(s))
  • Attachment: Crawler2.png
    (Size: 140.34KB, Downloaded 354 time(s))
  • Attachment: Crawler3.png
    (Size: 89.33KB, Downloaded 348 time(s))
Re: Rotating Wheels [message #84592 is a reply to message #84590 ] Sat, 08 February 2014 23:04 UTC Go to previous messageGo to next message
avatar HOLDEN8702  is currently offline HOLDEN8702
Hi.
The rotatory axes works in my 1/72 and 1/50 armored wagons.
https://www.shapeways.com/shops/panzervstanks?section=Armore d+Trains+1%2F72&s=0
This 1/56 model also has a rotatory system, and also a steering system for both axis. Unfortunately, the costumer doesn't write to tell me about it yet.
https://www.shapeways.com/model/1644778/1-56-fiat-spa-autopr otetto-s37.html?li=shop-results&materialId=6
index.php?t=getfile&id=51482&private=0
Also, even this 1/148 tiny flakvierling rotates its guns printed in one only part.
index.php?t=getfile&id=51483&private=0
If you have let enough clearance space between parts, It has to work (after cleaning, of course). I usually let 0,4 -0,5 mm. in clearance, then 1mm. is more than enough.
Good luck with your awesome buggy!
Luis
Re: Rotating Wheels [message #84594 is a reply to message #84592 ] Sat, 08 February 2014 23:20 UTC Go to previous messageGo to next message
Shapeways Crew
Thanks for the input. Your parts look great. I'm very impressed with the steering mechanisms; that is really cool.
But now that you mentioned that your wheels have half the clearance as mine, it makes me wonder if the wheels will be too loose on the buggy...
Re: Rotating Wheels [message #84599 is a reply to message #84594 ] Sun, 09 February 2014 03:14 UTC Go to previous messageGo to next message
All four axles on this model rotate...
The center two axles are also on swing arms such that they can raise & lower.
For FUD.. keep it a 0.05mm gap, and you can do wondrous things.
https://images1.sw-cdn.net/model/picture/674x501_279037_132297_1338413387.jpg
Re: Rotating Wheels [message #84632 is a reply to message #84599 ] Sun, 09 February 2014 23:10 UTC Go to previous messageGo to next message
Shapeways Crew
Will FUD be flexible enough for springs?
Re: Rotating Wheels [message #84665 is a reply to message #84632 ] Mon, 10 February 2014 14:08 UTC Go to previous messageGo to next message
I haven't direct experiences with FUD, I'm WSFadict, but my french costumers of Z scale trains have broken wagons only cleaning it or trying to make it a hole... I don't bet on it for flexible springs.
But WSF is enough flexible to do this:
index.php?t=getfile&id=51601&private=0
  • Attachment: 9pth.jpg
    (Size: 80.63KB, Downloaded 280 time(s))
Re: Rotating Wheels [message #85267 is a reply to message #84590 ] Sat, 22 February 2014 22:30 UTC Go to previous message
https://www.shapeways.com/tutorials/designing_mechanical_par ts_for_3d_printing
https://www.shapeways.com/tutorials/designing_mechanical_par ts_3d_printing_the_whoosh
0.2mm clearance is possible with WSF :)
Forget FUD, it is UV cured acrylic and quite brittle, so won't work for any parts that would take continued abuse such as springs.
Previous Topic:Advice on my models...
Next Topic:Corvo's Mask
