separate parts
separate parts [message #84184] Sat, 01 February 2014 01:31 UTC Go to next message
avatar raw_gd  is currently offline raw_gd
So I know in the description for silver, it says that multiple parts are not permitted.
However, when printing components for a hinge, I uploaded an .obj with 3 separate parts;
-a pin
-the main jewellery piece
-a piece that will clip in
And I received no errors.
Would I get the error as it was checked over at order time?
Or is Shapeways allowing the pieces due to their tiny size?
Re: separate parts [message #84198 is a reply to message #84184 ] Sat, 01 February 2014 19:28 UTC Go to previous messageGo to next message
I believe the automated check is for more basic things like bounding box size limits (both maximum and minimum), material thickness, and other fundamental properties. I don't think it looks for violations of "mulitple part" rules and such.
Re: separate parts [message #84255 is a reply to message #84184 ] Mon, 03 February 2014 14:09 UTC Go to previous message
Correct, if you order, it should fail when it goes through a manual check.
Previous Topic:Wire thickness/ Making the object from "hollow" to "solid"?
Next Topic:Wall thickness
