Holes in my model?
Holes in my model? [message #84073] Wed, 29 January 2014 21:33 UTC Go to next message
avatar LemonDread  is currently offline LemonDread
I need a little bit of help, hopefully someone can tell me how to fix this :(
I've been working on a model, and I finally had it how I wanted it, correctly sized and everything seemed good. I've been working in Blender, so I exported the file into OBJ to upload it to shapeways.
Except every time I try uploading it on shapeways it's full of holes! Everything looks fine to me in blender, but as soon as I upload into shapeways it's all broken up. I've tried exporting in a few different file types and so far it's always the same problem.
I really hope someone can help me, I'm new to modeling and I'm at my wits end...
index.php?t=getfile&id=50746&private=0
index.php?t=getfile&id=50747&private=0
Re: Holes in my model? [message #84077 is a reply to message #84073 ] Wed, 29 January 2014 22:18 UTC Go to previous messageGo to next message
It might be that some of your Normals are flipped.
In Edit Mode select all Vertices (press 'A' once or twice) and then from the Mesh Tools side menu choose Normals: Recalculate.
Hope this helps...
Re: Holes in my model? [message #84082 is a reply to message #84077 ] Wed, 29 January 2014 22:47 UTC Go to previous messageGo to next message
Another option is to use Blender to export the file as an STL and then open it with Netfabb Basic (free from www.netfabb.com)
It will show you quickly if you have any flipped normals.
Re: Holes in my model? [message #84084 is a reply to message #84073 ] Wed, 29 January 2014 23:03 UTC Go to previous message
That worked, thanks so much both of you! T_T;
Previous Topic:Any software to control thickness/circumference of wires for 3D printing?
Next Topic:Can't import model with color
