Ceramics wall thickness
Ceramics wall thickness [message #83604] Wed, 22 January 2014 10:10 UTC Go to next message
avatar guusbaggermans  is currently offline guusbaggermans
I'm currently designing a small bowl, that I want to print in ceramics.
The wall thickness checker is warning me about a 3mm minimum wall thickness, and I wonder if anybody has any experience in going more towards 2mm. Does it get very fragile? The total dimensions of the bowl are about a 13cm sphere.
Re: Ceramics wall thickness [message #83619 is a reply to message #83604 ] Wed, 22 January 2014 14:08 UTC Go to previous messageGo to next message
No one should have experience at 2mm as 3mm is the minimum.
Re: Ceramics wall thickness [message #83951 is a reply to message #83604 ] Tue, 28 January 2014 00:52 UTC Go to previous message
avatar AlanHudson  is currently offline AlanHudson
guusbaggermans wrote on Wed, 22 January 2014 10:10
I made a bowl recently with these dimensions: 11.762 w x 3.39 d x 11.728 h cm
It needed to 4mm thick as it was rejected at 3mm. The rules for thickness are. I made my bowl below 300mm to stay under 4mm thickness.
If bounding box x+y+z is 120-200mm: 3mm · x+y+z is 200-300mm: 4mm · x+y+z is 300-400mm: 6mm
You can see it here: https://www.shapeways.com/model/1475676
Director 3D Tools
Previous Topic:Printing hinges
Next Topic:Modeling a Drill
