Home » Support » 3D Design » whats wrong with this model?
whats wrong with this model? [message #83233] Wed, 15 January 2014 17:15 UTC Go to next message
avatar robbyvw  is currently offline robbyvw
hi everybody,
i am completely new over here and don't really know what i do wrong about my design.
when i uploaded the model, i really would like to print it with steel, steel ain't a select-able option.
can someone give me the right information to help me?
thanks in advance!
Robby
Re: whats wrong with this model? [message #83234 is a reply to message #83233 ] Wed, 15 January 2014 17:50 UTC Go to previous messageGo to next message
The minimum size for stainless is 3mm x 3mm x 3mm. Your part is 2.12mm x 1.23mm x 5.48.
[Updated on: Wed, 15 January 2014 18:05 UTC]
Re: whats wrong with this model? [message #83235 is a reply to message #83233 ] Wed, 15 January 2014 17:57 UTC Go to previous message
Hi Robby,
There's a load of internal geometry, all those unnecessary lines and faces, if you've got an internal face it in affect becomes two individual objects, the whole model needs to be one single solid model, nothing else inside that doesn't need to be there, if that makes sense?
http://imagizer.imageshack.us/v2/800x600q90/19/httq.png
Those white faces are reversed and they're inside and shouldn't be there, also looks like a load of unneeded lines.
Hope this helps,
Tom
Previous Topic:Minimum hole size for FUD or detailed plastic
Next Topic:Asking experienced users: Ball-joint, clearance, and pegs.
