Home » Support » 3D Design »
Minimum hole size for FUD or detailed plastic
Minimum hole size for FUD or detailed plastic [message #83179] Tue, 14 January 2014 20:46 UTC Go to next message
avatar joshua1745  is currently offline joshua1745
I would like to create a nozzle to shoot out liquid similar to a that found in a spray bottle. What is the minimum hole size that could accomplish this for FUD or detailed plastic? Which would be better (FUD or detailed plastic)? Most spray bottles have an opening around 0.2mm diameter or even smaller. It needs to be only 1-2mm thick.
Re: Minimum hole size for FUD or detailed plastic [message #83181 is a reply to message #83179 ] Tue, 14 January 2014 20:51 UTC Go to previous message
The minimum clearance for FUD is 0.05mm and the minimum for Detail is 2mm. So that should be the safe size for the diameter of a hole.
Previous Topic:Using Mirror Modifier in blender- help needed.
Next Topic:whats wrong with this model?
