Home » Community » It arrived! » The longest object I've ever had printed
The longest object I've ever had printed [message #82755] Wed, 08 January 2014 07:13 UTC Go to next message
I wanted to print the longest object possible with Shapeways. I though the main limitations were:
- the bounding volume (15x15x15xm for White Strong and Flexible Polished)
- the number of triangles (1'000'000 now, but I remember a time when you could bypass this limit)
I needed something that could be unfold to get bigger than this initial volume, so I choose to design a simple chain.
I first designed a simple link made of two circular loops, intersecting in a perpendicular direction by their sides (two tori to be precise).
I reduced the number of polygons as much as I could without scarifying the shape, and the result was an object with 1176 triangles.
Then I put as much of these links as I could to make a closed loop.
My first attempt was a loop of 824 of those links (969'024 triangles). As you can see, in theory, I could put 26 more links but it was not esy because the chain had to form a closed loop, so the end of the chain had to join the beginning of it, whereas staying into the maximum bounding volume. In other words, I had to fold the chain several times to fit it into this volume and thus the total length had to be a multiple of a certain basic length.
Unfortunately when I uploaded the model, I got an error, saying basically that the Meshmedic program (that check if all is OK with your model) failed to merge the shells. This was quite frustrating because there is no shell to merge: each shell (separate part) is interlocked with two other, but non is intersecting another.
But this means that the number of shell (probably also depending on the number of polygons) is an undocumented limit.
So I reduced the number of shells to 758 then to 692 and finally the 626-link version was uploaded successfully.
index.php?t=getfile&id=48940&private=0
So the version available is made of 626 links and has 736'176 triangles, which is not bad at all. Each link add a length of 6 mm so the total length is in theory 3.76 meters. As there is a clearance of 0.5mm the actual length is more that 4 meters (that you have to fold into two since it is a closed loop).
Here is a video of the result (with a bit of me for the scale) :
http://youtu.be/yfSM1TBtBrc
And you, did you manage to print something bigger? In this case how many shells and how many triangles?
  • Attachment: IMG_7019.JPG
    (Size: 180.26KB, Downloaded 428 time(s))
[Updated on: Wed, 08 January 2014 07:20 UTC]
Re: The longest object I've ever had printed [message #82761 is a reply to message #82755 ] Wed, 08 January 2014 10:07 UTC Go to previous messageGo to next message
cool :)
its always interesting how designers push the possibility of the 3D-Printing technology.
would be interesting where the problem comes from or where is the limit.
I am not sure, but IMO was in there a blog about folding a chain armor or other clothes so it can be printed? IMO a chain armor has much more shells.
[Updated on: Wed, 08 January 2014 10:08 UTC]
Re: The longest object I've ever had printed [message #82793 is a reply to message #82755 ] Wed, 08 January 2014 15:58 UTC Go to previous messageGo to next message
Quaternary tree mobile (level 6) - 1365 shells, 341200 triangles. If there are fewer polygons then it gets through the spurious shell merging more quickly - before it times out and fails the model. Yes, it is very annoying to have to downgrade the resolution of a perfectly good model to get it through the upload process.
Re: The longest object I've ever had printed [message #82799 is a reply to message #82755 ] Wed, 08 January 2014 17:37 UTC Go to previous messageGo to next message
Tres cool Vincent :)
The limit is not the number of shells, but how the number of shells vs the number of triangles affects the ability of MeshMedic to verify the model before it hits a pre-determined time-out limit (20 minutes iirc) - 2034 (or more) shells is possible, however the model has only 73728 triangles, a bit of a bummer really when 3D printed chainmaille clothing is doable.
Re: The longest object I've ever had printed [message #82812 is a reply to message #82755 ] Wed, 08 January 2014 19:22 UTC Go to previous messageGo to next message
One wonders how much longer a chain could be made by using flat faced links instead of toroidal ones. MeshMedic might have less trouble with the quantity of shells, too?
Re: The longest object I've ever had printed [message #82816 is a reply to message #82812 ] Wed, 08 January 2014 20:25 UTC Go to previous messageGo to next message
FreeRangeBrain wrote on Wed, 08 January 2014 19:22
Using the largest print size for WSF, links of two sizes could be made, one in the region of 640mm long the other maybe 8mm long, each size link could be constructed in a similar manner with 24 triangles per link using a triangular cross-section for the 'wire' making the links. How many fits into the printer size of 650x350x550mm, I'll leave up to Magic ;)
Re: The longest object I've ever had printed [message #82817 is a reply to message #82816 ] Wed, 08 January 2014 20:57 UTC Go to previous messageGo to next message
If the 640mm links can be aligned on the horizontal plan of 550mm by letting 8mm from link to link you can put 68 of them horizontally and then make 43 identical layers. This is 68x43 = 2924 links of 640mm plus the same number of 8mm. the length would be 648x2924 = 1'894'752mm, that is a little less than 2km (for only 2924x2x24 = 140'352 triangles). if the density is, say, 20% the volume would be 65x35x55x0.2 = 25'025 cc and the price a little more than $35'000.
Am I right?
Oops, I forgot the discount for large volume WSF...
Re: The longest object I've ever had printed [message #82819 is a reply to message #82817 ] Wed, 08 January 2014 21:05 UTC Go to previous messageGo to next message
Mathematics isn't my strongest area, so I'll just agree ;)
It would be an interesting experiment - are there any Guiness records for 3D printed items yet?
(My idea on the world record bit if Shapeways decide to take it up as a publicity stunt)
Re: The longest object I've ever had printed [message #82820 is a reply to message #82819 ] Wed, 08 January 2014 21:13 UTC Go to previous messageGo to next message
Here's some competition on chain length: Hyperform - Longest Chain.
Re: The longest object I've ever had printed [message #82821 is a reply to message #82820 ] Wed, 08 January 2014 21:26 UTC Go to previous messageGo to next message
There are two problems with our theory:
- at 64cm long the a link made of a wire of 2 or 3 mm diameter will not be very sturdy.
- the weight of the whole chain would be 25kg. The first link must support all this weight...
Re: The longest object I've ever had printed [message #82822 is a reply to message #82821 ] Wed, 08 January 2014 21:48 UTC Go to previous messageGo to next message
I'm thinking the same, not only long, but strong too - I have some chain of 0.7mm WSF 'wire' rings, time for a test.
Re: The longest object I've ever had printed [message #82847 is a reply to message #82822 ] Thu, 09 January 2014 06:34 UTC Go to previous messageGo to next message
For a same quantity of matter (that is for a same weight) a hollow cylinder is sturdier than a solid one. Should we try hollow links?
Re: The longest object I've ever had printed [message #82848 is a reply to message #82847 ] Thu, 09 January 2014 07:15 UTC Go to previous messageGo to next message
Here is a hollow link that could be a first try:
index.php?t=getfile&id=49047&private=0
It is 192 triangles (it seems that the 1 million triangle limit is not the most important one)
Its external size is 18x12x3 mm with an internal hole of 12x6mm
The wire is 3x3 mm with a hole of 1x1 mm
Each time you add a link you add 12 mm
If we were not limited by the bounded volume (or the number of shells) but only by the number of polygons, we could make a chain of 1000000/192*12/1000 = 62.5 meters. That's much less than our initial calculation because I did not consider the two sizes of links.
How long could this link be made without compromising its sturdiness?
  • Attachment: link.jpg
    (Size: 12.43KB, Downloaded 289 time(s))
[Updated on: Thu, 09 January 2014 07:17 UTC]
Re: The longest object I've ever had printed [message #82859 is a reply to message #82848 ] Thu, 09 January 2014 10:46 UTC Go to previous messageGo to next message
avatar Wahtah  is currently offline Wahtah
@Magic: nice chain!
@stop4stuff: with regards to 0.7mm WSF links: I don't think it's worth trying that, I had this moebius strip printed in WSF with 1mm links and many of them were broken by the time I got them:
index.php?t=getfile&id=49052&private=0
index.php?t=getfile&id=49053&private=0
  • Attachment: Moebius.PNG
    (Size: 454.05KB, Downloaded 269 time(s))
  • Attachment: Moebius2.PNG
    (Size: 306.69KB, Downloaded 268 time(s))
[Updated on: Thu, 09 January 2014 10:51 UTC]
Re: The longest object I've ever had printed [message #82861 is a reply to message #82859 ] Thu, 09 January 2014 12:04 UTC Go to previous messageGo to next message
You can reduce it to 112 triangles if you close the holes on the sides:
index.php?t=getfile&id=49054&private=0
  • Attachment: Link.jpg
    (Size: 115.40KB, Downloaded 258 time(s))
Re: The longest object I've ever had printed [message #82889 is a reply to message #82861 ] Thu, 09 January 2014 18:49 UTC Go to previous messageGo to next message
The side holes were for an easier cleaning of the internal powder. I am wondering if we could have a "U" section, instead of a hollow square section. It would be lighter and even easier to clean.
Re: The longest object I've ever had printed [message #87802 is a reply to message #82889 ] Sun, 13 April 2014 14:12 UTC Go to previous message
A little bird told me that this problem of shell limits will soon be fixed.
So, it is time to think bigger (well longer).
So I have designed a new link with less triangles (272 instead of 1176).
index.php?t=getfile&id=57010&private=0
If the only limit is the number of triangles (1 million) then I can print 3676 links each on adding 6 to 6.5mm of length, which would give a chain whose total length will be 22 or 23 meters. If I am not wrong the weight would be 128g and the price something like $195...
Previous Topic:Custom Bottle opener
Next Topic:Pasta stamps for making Ligurian pasta shape croxetti
