3-D Newb needs help with manifold problems (I know....)
3-D Newb needs help with manifold problems (I know....) [message #8103] Sun, 06 December 2009 00:40 UTC Go to next message
avatar birdie15  is currently offline birdie15
Guys, I'm new to 3d design. I've been using sketchup to draw some parts. I uploaded the first one to Shapeways as a VMRL and got the manifold error message.
I can't find any way of finding or eliminating the manifold errors in Sketchup.
Can any of you guys help me out?
I've attached the orignal sketchup file and the WRL.
Simon
  • Attachment: brake.wrl
    (Size: 801.88KB, Downloaded 115 time(s))
  • Attachment: brake.skp
    (Size: 257.12KB, Downloaded 156 time(s))
Re: 3-D Newb needs help with manifold problems (I know....) [message #8109 is a reply to message #8103 ] Sun, 06 December 2009 14:43 UTC Go to previous messageGo to next message
Hi Birdie 15, I've had a look at your model a fixed it for you.
I had to re rmodel it, using your model to trace over.
Double check the dimensions before uploading it for printing.
if your're happy leave a post here http://www.shapeways.com/forum/index.php?t=msg&th=1584&a mp;start=0&S=4e30ee706fc8f9813de5f4ce956c07b9
Cheers
V
http://dotsan.com
Re: 3-D Newb needs help with manifold problems (I know....) [message #8112 is a reply to message #8103 ] Sun, 06 December 2009 17:34 UTC Go to previous messageGo to next message
Hi Virtual V,
Thanks so much Smile
I am having problems with the dimensions when uploading to shapeways. The original model was drawn using centimetres in Sketchup.
If I upload using the millimetres or metres default, it comes out as too small or too large - the numbers are correct but the units don't translate over correctly.
How should I correct this?
Simon
Re: 3-D Newb needs help with manifold problems (I know....) [message #8114 is a reply to message #8112 ] Sun, 06 December 2009 20:19 UTC Go to previous messageGo to next message
Manged to scale it correctly with Accutrans, thanks again for the work Very Happy
Re: 3-D Newb needs help with manifold problems (I know....) [message #8133 is a reply to message #8114 ] Mon, 07 December 2009 18:45 UTC Go to previous message
Following up on this: It would be great -- and probably not difficult -- for SW to support "centimeters" as a scale option on uploading STL files. At least in Blender, the natural coordinates for modeling (using the default grid size, default view, typical scale of a SW object given current pricing, etc.) seem to match 1 unit = 1 cm most closely. Allowing cm as a scale option might lower an unnecessary barrier.
[Updated on: Mon, 07 December 2009 18:46 UTC]
Previous Topic:Manifold error, tubular object
Next Topic:just another...manifold problem
