Home » Community » Instructions »
NCNGRR Caboose No.1
NCNGRR Caboose No.1 [message #80760] Sun, 08 December 2013 11:45 UTC Go to next message
avatar pinddle  is currently offline pinddle
This kit provides the basic body parts to make a HO scale model.
http://www.shapeways.com/model/1359816/nevada-county-ngrr-c aboose-hon3.html?li=my-models&materialId=6
This is what you get.
index.php?t=getfile&id=46848&private=0
Paint the parts ( I used acrylic paints ) then remove the roof-walks.
index.php?t=getfile&id=46849&private=0
The roof-walk lengths have been corrected in the final design.
If you want to fit truss-rods, drill 4 holes in the floor, as below. I've used EZ line here.
index.php?t=getfile&id=46850&private=0
Glaze the windows and add weight now before fitting the roof.
Make the roof from some thin styrene sheet. The main roof is 89x28.5 mm, the cupola is 15x20 mm. Both are scored down the middle to for the shape of the roof.
index.php?t=getfile&id=46851&private=0
The smoke stack is one of my roof vents I had spare. It's not quite right, but serves as an example.
Kadee 714 couplers fit between the beams of the chassis.
As far as I can tell, the airbrake cylinder was directly below the cupola, between the wheels. I haven't included one as it would probably get in the way.
  • Attachment: NCNG_1.jpg
    (Size: 70.26KB, Downloaded 303 time(s))
  • Attachment: NCNG_2.jpg
    (Size: 105.36KB, Downloaded 294 time(s))
  • Attachment: NCNG_3.jpg
    (Size: 98.56KB, Downloaded 284 time(s))
  • Attachment: NCNG_4.jpg
    (Size: 79.60KB, Downloaded 284 time(s))
[Updated on: Sun, 08 December 2013 18:47 UTC]
Re: NCNGRR Caboose No.1 [message #80761 is a reply to message #80760 ] Sun, 08 December 2013 11:52 UTC Go to previous message
The end hand rails are 0.5mm brass rod bent to shape using my HOn30 handrail jig.
http://www.shapeways.com/model/1328568/handrail-jig-hon30.h tml?li=my-models&materialId=6
Drill holes in the end beam, using the handrails as a guide.
index.php?t=getfile&id=46852&private=0
index.php?t=getfile&id=46853&private=0
Note, only one handbrake wheel, at the cupola end.
It is sitting on HOn3 caboose trucks.
http://www.shapeways.com/model/1347793/hon3-caboose-truck-k -x4.html?li=my-models&materialId=6
  • Attachment: NCNG_6.jpg
    (Size: 77.74KB, Downloaded 274 time(s))
  • Attachment: NCNG_5.jpg
    (Size: 82.72KB, Downloaded 281 time(s))
[Updated on: Sun, 08 December 2013 12:00 UTC]
Previous Topic:HO Scale Narrow Gauge Coaches
Next Topic:N to HOn30 2-8-0 Steam loco conversion project
