Image popper
Image popper [message #77790] Tue, 29 October 2013 18:06 UTC Go to next message
avatar Gandalfthe5000ator  is currently offline Gandalfthe5000ator
Shapeways used to let you put a base rectancle of material behind a popped 2D image. I need to makr stamps out of 2D images. Any ideas on how to do that?
Re: Image popper [message #77792 is a reply to message #77790 ] Tue, 29 October 2013 18:47 UTC Go to previous messageGo to next message
The only current way to do this is to add a grey background to your image. I've requested that this option be brought back.
Re: Image popper [message #77793 is a reply to message #77790 ] Tue, 29 October 2013 19:00 UTC Go to previous messageGo to next message
Here's an example with a grey background http://i.imgur.com/M1urUPE.png
and the resulthttp://i.imgur.com/4OE2UF7.png
[Updated on: Tue, 29 October 2013 19:01 UTC]
Re: Image popper [message #77798 is a reply to message #77793 ] Tue, 29 October 2013 20:46 UTC Go to previous messageGo to next message
But will it be thick enough with grey?
Customer Service Coordinator
Shapeways
Re: Image popper [message #77839 is a reply to message #77798 ] Wed, 30 October 2013 10:27 UTC Go to previous messageGo to next message
The image popper linearly maps the brightness of your image to thickness. So, if you set a 3mm thickness in total, 100% black = 3mm thick. Use a 50% black background for a 1.5mm thick back plate etc.
To be 100% sure, you can download the model and measure it in NetFabb Smile
Re: Image popper [message #77840 is a reply to message #77839 ] Wed, 30 October 2013 10:33 UTC Go to previous messageGo to next message
thank you for explaining Bart Smile
Shapeways
Re: Image popper [message #77928 is a reply to message #77840 ] Thu, 31 October 2013 12:56 UTC Go to previous messageGo to next message
It's not often that I know something that you don't, so I couldn't let that opportunity pass Wink
Re: Image popper [message #78263 is a reply to message #77790 ] Wed, 06 November 2013 01:07 UTC Go to previous message
avatar eXtrudy  is currently offline eXtrudy
if you have a Windows PC, you could take a look at my free 2d to 3d application "eXtrudy", which gives you a lot of possibilities to turn your drawing/photo into an extruded 3d object:
https://www.shapeways.com/forum/index.php?t=msg&th=14768 &start=0&
best regards, Hendrik
www.facebook.com/eXtrudy
Previous Topic:Little Help for a new Shop
Next Topic:How to make lego models to print
