Using inventor to create a STL
Using inventor to create a STL [message #74297] Thu, 05 September 2013 19:06 UTC Go to next message
avatar Arcathorn  is currently offline Arcathorn
Greetings all!
This is my first time trying to create a model to be printed out. I have used inventor for years and figured this would be something I would enjoy a lot. However on my first try I am running into a problem. I used inventor to create a model that measures at 4.5 inches. I then uploaded it to the site and it came back at a whopping 11.5 inches in size...you can imagine the cost increase there. I can't seem to get it to upload at the correct size and I have not been able to figure it out. Does anyone have any hints?
Re: Using inventor to create a STL [message #74300 is a reply to message #74297 ] Thu, 05 September 2013 19:20 UTC Go to previous messageGo to next message
What file type are you uploading?
Re: Using inventor to create a STL [message #74303 is a reply to message #74297 ] Thu, 05 September 2013 19:53 UTC Go to previous messageGo to next message
avatar GarySG  is currently offline GarySG
The problem you're likely encountering is when you export an STL from Inventor, the default unit is centimeters. Go into the settings as you're exporting it, and change that to inches. You should be set to go.
[Updated on: Thu, 05 September 2013 20:09 UTC]
"Hm, I'm so hungry I could eat an entire cow. Gerard, fire up the printer!"
Re: Using inventor to create a STL [message #74341 is a reply to message #74303 ] Fri, 06 September 2013 14:22 UTC Go to previous messageGo to next message
Fixed it! As you guess the problem was in the conversion. I just had to go down to options as I was saving it and set the correct units. Once that was done presto. Thank you for all your help...........ya know this really is quite fun to play around with....Might be something I get more into as time goes on. Thanks again everyone
"Do or do not there is no try"-Yoda
Re: Using inventor to create a STL [message #76058 is a reply to message #74341 ] Fri, 04 October 2013 00:20 UTC Go to previous messageGo to next message
avatar builder_bob  is currently offline builder_bob
I'm haveing the same problem you had, how'd you get to the spot where you can change the export units?
Re: Using inventor to create a STL [message #76061 is a reply to message #76058 ] Fri, 04 October 2013 00:54 UTC Go to previous message
never mind i got it!
Previous Topic:The world's craziest toothbrush cleans your teeth in six seconds and is 3D printed
Next Topic:IP Addresses in Private Messages?
