Home » Support » 3D Design »
Google Sketchup 8 - 3D Text inaccurate dimensions????
Google Sketchup 8 - 3D Text inaccurate dimensions???? [message #74831] Sun, 15 September 2013 15:16 UTC Go to next message
avatar Rustysworkshop  is currently offline Rustysworkshop
I was trying to use google sketchup to create some 3D text so I selected the 3D text tool and entered the Height as 30.00mm yet when I measure the text using the tape measure it measures 28.50mm. I need it to be precise how can I get the text to be exactly 30mm high?
Thanks in advance.
Re: Google Sketchup 8 - 3D Text inaccurate dimensions???? [message #74912 is a reply to message #74831 ] Tue, 17 September 2013 09:33 UTC Go to previous messageGo to next message
avatar JACANT is currently online JACANT
Use the scale icon pick the top grip and type in the scale box 1.052631578947368
Which is 30 divided by 28.5
Re: Google Sketchup 8 - 3D Text inaccurate dimensions???? [message #74917 is a reply to message #74912 ] Tue, 17 September 2013 10:05 UTC Go to previous messageGo to next message
avatar coaster  is currently offline coaster
Cant you just measure it and type in 30.00mm and you will be asked if you want to rescale and you click yes.....then 28.5 becomes 30.????
Re: Google Sketchup 8 - 3D Text inaccurate dimensions???? [message #75331 is a reply to message #74831 ] Tue, 24 September 2013 02:32 UTC Go to previous messageGo to next message
avatar TrainThingz  is currently offline TrainThingz
I use SketchUp too, and I think I know what's happening there... it's caught me, as well.
When you stretch or shrink text, (or any object, really...) there are THREE handles at each point - Top, Bottom, and Middle.
If you pick the top or bottom handle, then the text THICKNESS will be scaled diagonally through the center along with it's height and breadth! That's probably what's happening, especially if you're grabbing a corner.
If you want to adjust the size in only ONE dimension, then you have to scroll in VERY close so that you can see the MIDDLE handle. When you select that one, you will adjust ONLY the object's X, Y, or Z dimension without affecting the others. This will let you make those fixes without changing the thickness.
[Updated on: Tue, 24 September 2013 02:33 UTC]
Re: Google Sketchup 8 - 3D Text inaccurate dimensions???? [message #75375 is a reply to message #75331 ] Tue, 24 September 2013 15:21 UTC Go to previous message
Thank you everybody for all the help, I have managed to fix it now.
Previous Topic:Hollowing out first design?
Next Topic:Which is the best for 3D design: pro/e, solidworks, 3dmax, inventor, maya, or...?
