Supported applications, I could use a little help
 () 1 Vote(s)
Re: Supported applications, I could use a little help [message #72445 is a reply to message #9996 ] Wed, 31 July 2013 15:23 UTC Go to previous messageGo to next message
avatar 3D_Makery  is currently offline 3D_Makery
Mathematica has a native support for OBJ. I think!
http://reference.wolfram.com/mathematica/guide/3DGeometryAnd ModelingFormats.html
Re: Supported applications, I could use a little help [message #72821 is a reply to message #9996 ] Thu, 08 August 2013 15:55 UTC Go to previous messageGo to next message
avatar Ken_Bringhurst  is currently offline Ken_Bringhurst
Strata actually has four variants of Design 3D (3 sold on the Mac App store and 1 directly by the company) that support VRML2, OBJ and Collada DAE:
Strata Design 3D SE
Strata Design 3D SE 7
Strata Design 3D CXi
Strata Design 3D CX
Strata Foto 3D (uses a standard digital camera to capture fully textured 3D models) supports VRML2 and Collada DAE and comes in two versions:
Strata Foto 3D SE
Strata Foto 3D CX
Thanks.
Re: Supported applications, I could use a little help [message #73282 is a reply to message #72821 ] Mon, 19 August 2013 16:32 UTC Go to previous messageGo to next message
avatar Carlomez  is currently offline Carlomez
I use Creo Elements / direct modeling express 4.0, which is the free 3D software from PTC (download available at http://www.ptc.com/products/creo-elements-direct/modeling-ex press/).
It uses a proprietary format, but you can export both STL and VRML (version 1.0 and 2.0) files for 3D Printing. When using the STL format, remember to check the Options: usually the default values for Max Deviation (Distance and Angle) are a bit too large; if you have curved surfaces, reduce the angle to obtain smooth surfaces.
Carlo
Re: Supported applications, I could use a little help [message #73590 is a reply to message #73282 ] Fri, 23 August 2013 21:07 UTC Go to previous messageGo to next message
avatar Mazzmn  is currently offline Mazzmn
FYI Here's a tutorial on how I used Google Sketchup and Shapeways to create some 3D printed objects
http://www.instructables.com/id/Create-a-3D-Printed-Secret-C ode-Wheel-with-Shapewa/
Also a presentation I did on it here
https://docs.google.com/presentation/d/1gaof8fAK_NcaIvF4osNT PoAK7Pywj49B0Zom_kiSyTU/edit#slide=id.p
Re: Supported applications, I could use a little help [message #73889 is a reply to message #9996 ] Thu, 29 August 2013 14:41 UTC Go to previous messageGo to next message
avatar caryo12  is currently offline caryo12
Hi Bart,
IronCAD offers two 3D Design products that support STL, VRML, and the OBJ formats. Can you add these to your list. If you need the product for testing/verification, let me know.
Best Regards,
Cary
www.ironcad.com
Re: Supported applications, I could use a little help [message #74489 is a reply to message #9996 ] Tue, 10 September 2013 03:49 UTC Go to previous messageGo to next message
avatar 3defy  is currently offline 3defy
Hi Bart,
Could you please add 3Defy to the list of supported applications? We now allow users to export their 2D to 3D conversions in Shapeways-compatible X3D format.
http://www.3defy.com
I posted more info here:
https://www.shapeways.com/forum/index.php?t=msg&goto=744 88#msg_74488
[Updated on: Tue, 10 September 2013 03:50 UTC]
Re: Supported applications, I could use a little help [message #77272 is a reply to message #9996 ] Tue, 22 October 2013 03:31 UTC Go to previous messageGo to next message
avatar MaraJade  is currently offline MaraJade
I saw Solid Edge mentioned a long time ago but it's not in the main list. Does that mean it's not compatible or just overlooked?
Re: Supported applications, I could use a little help [message #77390 is a reply to message #9996 ] Wed, 23 October 2013 18:02 UTC Go to previous messageGo to next message
avatar evosoft  is currently offline evosoft
Hello Bart
I develop the PC/Mac applications listed below that support import & export of STL (ascii & binary), OBJ, and VRML.
ViaCAD 2D/3D
ViaCAD Pro
Shark LT
Shark FX
Regards
Tim Olson
EvoSoft
Re: Supported applications, I could use a little help [message #77710 is a reply to message #9996 ] Mon, 28 October 2013 17:31 UTC Go to previous messageGo to next message
avatar duram  is currently offline duram
I use Turbocad and it saves STL, OBJ, X3D, DAE, Collada or VRML97/2 files, which one file do you really prefer to use to print? which one give more details to the finish job? which one lose less info when exporting from the original twc (turbocad) file?
Re: Supported applications, I could use a little help [message #78325 is a reply to message #9996 ] Wed, 06 November 2013 15:09 UTC Go to previous messageGo to next message
avatar pdussart  is currently offline pdussart
Sir,
I am using Creo Elements Direct Modeling Express 4.0. It is edited by PTC.
This is an extremely powerful professional tool. It is a freeware as long as you limit your model in 60 assemblies. STL as output.
See http://www.ptc.com/products/creo-elements-direct/modeling-ex press/
Direct Modeling
Work with assemblies, parts, surfaces and wireframe models
Create and edit models using direct drag-and-drop techniques
Modify models using commands such as mirror, stretch and scale
Create and edit assemblies using either a top-down or bottom-up approach
Handling assemblies
Create assemblies that have unlimited unique parts Max 60
Share assemblies and parts; create once and share multiple instances
Manage and edit assemblies using the same drag-and-drop techniques used with files and folders
Associative 2D Drawings
Automatically create associative 2D drawings from 3D models
Update 2D drawings and dimensions automatically when the 3D model has been modified
3D Visualization
Use enhanced realism to generate a realistic model impression with shadows and reflections
Data Exchange
Import 3D geometry, and edit assemblies and parts automatically, as if the design data is native STEP, 3D IGES,
Import STEP and 3D IGES formats
Export and publish VRML and STL formats
Platform support
32-bit Editions of Windows® 7, Vista® and XP
64-bit Editions of Windows 7, Vista and XP
Licensing
Individual registered user license
Activate license through Internet connection
Re: Supported applications, I could use a little help [message #78360 is a reply to message #9996 ] Wed, 06 November 2013 21:09 UTC Go to previous messageGo to next message
DesignSpark Mechanical IT'S FREE
Saves as STL and OBJ
http://www.designspark.com/eng/nodes/view/type:page/slug:mec hanical
Re: Supported applications, I could use a little help [message #78874 is a reply to message #78360 ] Wed, 13 November 2013 14:15 UTC Go to previous messageGo to next message
avatar Kitty  is currently offline Kitty
There is a utility for Autodesk 123D design that doesn't come standard with 123D, called autodesk 3Dprint utility.
You can find it on the same site as 123D Design.
it is a standalone application that can hollow out solids in an .stl file.
Just load the .stl, and you are presented with a few options, like :
position the object to minimize the needed support material
show or hide the support material in prview
show the dimensions.
scaling
and most important : hollowing out the object where you can define wall thicknes
It will calculate cavities in the solids and after saving the changed .stl you can use your modelling application to remove cavities that are too small to be usefull and cut holes to the outside to remove support material from the inside.
Maybe usefull to mention it seperately in Supported Applications
Re: Supported applications, I could use a little help [message #80945 is a reply to message #27224 ] Tue, 10 December 2013 13:23 UTC Go to previous messageGo to next message
avatar PassionateShadow  is currently offline PassionateShadow
Is there away to make MudBox applications useable?
  • Attachment: Untitled.png
    (Size: 264.54KB, Downloaded 84 time(s))
Re: Supported applications, I could use a little help [message #80974 is a reply to message #72821 ] Tue, 10 December 2013 16:28 UTC Go to previous messageGo to next message
Strata now includes STL in Design 3D CX with version 7.5
Re: Supported applications, I could use a little help [message #81094 is a reply to message #9996 ] Thu, 12 December 2013 00:44 UTC Go to previous messageGo to next message
avatar eriksundheim  is currently offline eriksundheim
I have successfully created 3D designs and exported to *.STL files using Bentley Microstation. That should be on your list.
Erik
Re: Supported applications, I could use a little help [message #85958 is a reply to message #9996 ] Fri, 07 March 2014 22:36 UTC Go to previous messageGo to next message
avatar Somian  is currently offline Somian
the information about cheetah 3D isn't correct (or outdated). It supports obj natively.
Re: Supported applications, I could use a little help [message #86682 is a reply to message #9996 ] Mon, 24 March 2014 20:31 UTC Go to previous messageGo to next message
avatar punchfacechamp  is currently offline punchfacechamp
Autodesk Alias can export OBJ and STL formats
Re: Supported applications, I could use a little help [message #86958 is a reply to message #9996 ] Sun, 30 March 2014 18:44 UTC Go to previous messageGo to next message
avatar Shazam1842  is currently offline Shazam1842
Is Creo Parametric compatible? It is a branch of Auto Cad, but for 3D modeling?
Re: Supported applications, I could use a little help [message #86960 is a reply to message #86958 ] Sun, 30 March 2014 18:53 UTC Go to previous messageGo to next message
avatar IanJeffray  is currently offline IanJeffray
Creo Parametric has no relation to Auto CAD. Creo (Formerly Pro/Engineer) is an industrial grade CAD tool, well suited for design for 3D printing ... I've used it for models printed at Shapeways with good success.
Re: Supported applications, I could use a little help [message #86988 is a reply to message #86958 ] Mon, 31 March 2014 07:16 UTC Go to previous messageGo to next message
Shazam1842,
Regarding Creo, see my message dated from November 2013. I have to add that this freeware is also running on Windows 8. I used this tools since 2010 and have produced 3D designs through Shapeways without a glitch.
The full version and its numerous add-ons is also a parametric tool fully compatible with STL files production.
Regrads, Philippe
Re: Supported applications, I could use a little help [message #87094 is a reply to message #9996 ] Wed, 02 April 2014 02:24 UTC Go to previous messageGo to next message
avatar Archigreen  is currently offline Archigreen
I've been working with BIM program called ArchiCAD 17 for a long time and I was surprised it is not on your list.
It can save files as a STL.
Kind regards,
Franz
index.php?t=getfile&id=55845&private=0
Re: Supported applications, I could use a little help [message #87505 is a reply to message #87094 ] Tue, 08 April 2014 17:13 UTC Go to previous messageGo to next message
avatar J94R  is currently offline J94R
i use creo parametric 2.0 to design 3D objects, check it out from here:
Re: Supported applications, I could use a little help [message #88647 is a reply to message #9996 ] Mon, 28 April 2014 01:54 UTC Go to previous messageGo to next message
avatar kmyumeka  is currently offline kmyumeka
Shade 3D from http://www.mirye.net/shade-3d supported the following file formats,
STL, OBJ, COLLADA and VRML 2.0
Cheer,
KM
Re: Supported applications, I could use a little help [message #89194 is a reply to message #9996 ] Mon, 05 May 2014 23:11 UTC Go to previous messageGo to next message
avatar lynnfredricks  is currently offline lynnfredricks
Shade 3D, published by Mirye Software supports STL, OBJ and COLLADA natively and is available on Windows and Mac OS X.
http://www.mirye.net/images/products/shade14/shade-to-unity-bonko_560x315.jpg
Re: Supported applications, I could use a little help [message #89198 is a reply to message #52072 ] Tue, 06 May 2014 01:36 UTC Go to previous messageGo to next message
bartv wrote on Mon, 30 July 2012 10:00
I've updated Lightwave and Catia, thanks!
what about ArchiCAD? can you update to your selected list?
Re: Supported applications, I could use a little help [message #94020 is a reply to message #9996 ] Wed, 16 July 2014 04:32 UTC Go to previous messageGo to next message
avatar MLM247  is currently offline MLM247
I use Aspire by Vectric for 3D. It support exports not only into .STL but ai, photoshop etc.
Used a lot by the Shopbot crowd as it is the 3D upgrade to their 2D Vcarve software.
Mike, Austin TX
Re: Supported applications [message #101112 is a reply to message #9996 ] Mon, 13 October 2014 00:38 UTC Go to previous messageGo to next message
avatar tim_felbinger  is currently offline tim_felbinger
Photoshop CC 2014 update now has support for 3D printing including print profiles for shapeways materials.
More info here: http://www.photoshop.com/products/photoshop/3d/printing
Might be worth adding this to the list.
Re: Supported applications [message #101263 is a reply to message #101112 ] Wed, 15 October 2014 03:53 UTC Go to previous messageGo to next message
avatar pinman  is currently offline pinman
It would appear that the Makehuman open source for figure design can export in formats Shapeways supports.
http://www.makehuman.org
http://www.makehuman.org/doc/node/load_save_and_export.html
I did a search on Makehuman and there are a few cases of folks who have submitted items for a successful print.
Re: Supported applications, I could use a little help [message #101352 is a reply to message #9996 ] Thu, 16 October 2014 17:16 UTC Go to previous messageGo to next message
avatar ArbronImagineering  is currently offline ArbronImagineering
Siemens NX can export stl and vrml with good results. It is what I use and haven't had too many issues.
Kirk
alderfek@aol.com
North of Mason, South of Dixon, 2nd star to the right.
Re: Supported applications, I could use a little help [message #101444 is a reply to message #101352 ] Sun, 19 October 2014 11:14 UTC Go to previous messageGo to next message
avatar jumpjack  is currently offline jumpjack
Autodesk Meshmixer is free and can export to:
obj (compatible with sketchup PRO)
dae (compatible with sketchup free)
ply
stl ( (compatible with sketchup free + free plugin)
amf
wrl (compatible with sketchup PRO)
and it has a lot of powerful feaures to repair/fix models for printing.
It even has direct Shapeways upload option available.
Re: Supported applications, I could use a little help [message #105638 is a reply to message #9996 ] Sat, 20 December 2014 03:09 UTC Go to previous messageGo to next message
avatar HarrisTech69  is currently offline HarrisTech69
Google sketchup now exports stl as native. No longer plugin.
Re: Supported applications, I could use a little help [message #109110 is a reply to message #9996 ] Wed, 28 January 2015 20:10 UTC Go to previous messageGo to next message
avatar elliottrosenfeld  is currently offline elliottrosenfeld
Autodesk InfraWorks 2015 and Autodesk InfraWorks 360 2015 now support exporting 3D models in DAE, OBJ or FBX format.
See http://help.autodesk.com/view/INFMDR/2015/ENU/?guid=GUID-DAE EE753-535C-421F-98C2-BD1594FBBCCC for more information.
Also, fun food for thought, here's an article about how Autodesk teamed up with SteelBlue in 2014 to create 'the world's biggest 3D-printed city model' (of San Francisco) using InfraWorks: http://www.modernluxury.com/san-francisco/story/autodesk-jus t-created-the-worlds-biggest-3d-printed-city-model
Re: Supported applications, I could use a little help [message #110160 is a reply to message #9996 ] Tue, 10 February 2015 11:46 UTC Go to previous messageGo to next message
avatar isaachadad2  is currently offline isaachadad2
I would like to introduce Wizegem, our new web-based jewelry design app.
We have an API to shapeways for direct 3D printing from our tool.
You can find information at http://www.wizegem.com
Direct app link: http://app.wizegem.com
You can see 3D models examples easily created in our tool at shapeways shop: https://www.shapeways.com/shops/wizegem
(Cost is only shapeways services. We do not charge anything)
Read about us at the news: http://3dprint.com/38343/3d-print-jewelry-wizegem/
Regards,
Isaac Hadad
[Updated on: Tue, 10 February 2015 12:06 UTC]
Wizegem
Re: Supported applications, I could use a little help [message #111184 is a reply to message #9998 ] Thu, 26 February 2015 13:50 UTC Go to previous messageGo to next message
avatar sbhunterca  is currently offline sbhunterca
I'm another Alibre user and would like to add that the STL output has a number of variables which can be played with to optimize the output for complex models. Excellent program, very reasonable price with the power of many expensive high end packages.
As well, since its purchase by 3D Systems, it should more appropriately be called Geomagic Design.
Steve Hunter
Re: Supported applications, I could use a little help [message #114674 is a reply to message #9996 ] Tue, 28 April 2015 18:10 UTC Go to previous messageGo to next message
avatar mars0120  is currently offline mars0120
The new 3D CAD program Onshape exports STL files nicely. It is a cloud based program from the makers of Solidworks.
Re: Supported applications, I could use a little help [message #122923 is a reply to message #9996 ] Tue, 15 September 2015 22:16 UTC Go to previous messageGo to next message
avatar metabloxer  is currently offline metabloxer
The FreeCAD program in the list links to the SourceForge location, but they have since then moved their code to https://github.com/FreeCAD/FreeCAD, and their official site is http://www.freecadweb.org.
Re: Supported applications, I could use a little help [message #124895 is a reply to message #9996 ] Tue, 03 November 2015 09:55 UTC Go to previous messageGo to next message
avatar Cajari  is currently offline Cajari
I'm using SolidWorks (2014-2015) most of the time and it does natively export vrml97. It's a bit annoying to texture, but it works alright.
Re: Supported applications, I could use a little help [message #131325 is a reply to message #9996 ] Wed, 06 January 2016 15:15 UTC Go to previous messageGo to next message
Please update the Strata 3D entry to include STL and OBJ as "native" formats for the application. Thanks.
Re: Supported applications, I could use a little help [message #131327 is a reply to message #131325 ] Wed, 06 January 2016 15:25 UTC Go to previous message
avatar lgrfbs  is currently offline lgrfbs
Alibre Design is now Geomagic design.
Member of Report message to a moderator
Pages (4): [ «    1  2  3  4]
Previous Topic:Shapeways wont recognise zip containing .x3d file and texture
Next Topic:3dsMax .DAE Export
