Map Ring (Closed)
Map Ring (Closed) [message #73079] Wed, 14 August 2013 21:21 UTC Go to next message
avatar ElementSpirits  is currently offline ElementSpirits
EDIT: SOMEONE HAS THE JOB. THANK YOU FOR ALL THE REPLIES!
I had an idea for a ring I wanted to 3D print. It is a solid band with the 7 images extruded of the body, like the lettering here - https://www.shapeways.com/model/834367/ring-forever-size-13. html?li=curatedproductGroup&materialId=6
Reference here (correct dimensions and spacing) - http://i.imgur.com/UYNDfPg.png
I left the body a bit narrow, because I also want a small bevel on the top and bottom (just like 30-45 degrees or so), because it generally looks nicer. Reference pic for bevel - http://www.kriskate.com/924-2197-thickbox/beveled-edge-tungs ten-ring-w-black-diamond.jpg
I'll be uploading this to Shapeways for printing, so whatever format they accept is the one I'll need.
Ring size is size 9, and price is negotiable.
.AIs for the continents can be found here - http://jmp.sh/v/elnJZgzcML7KroYSZahz
PM me or comment on price, possibility, and time frame for the project.
If you need to cut out parts of the continents for it to print properly, just let me know.
[Updated on: Thu, 22 August 2013 23:04 UTC]
Re: Map Ring [message #73087 is a reply to message #73079 ] Thu, 15 August 2013 00:51 UTC Go to previous message
avatar bluelinegecko  is currently offline bluelinegecko
PM sent
Previous Topic:help needed
Next Topic:Looking for 1/24 scale wheel designer
