How is the Min Escape Hole defined?
How is the Min Escape Hole defined? [message #72773] Wed, 07 August 2013 17:37 UTC Go to next message
avatar PointHappy  is currently offline PointHappy
For Sand Stone, the property spec is Min Escape Hole: One hole: 25mm, Two holes: 15mm, Four holes: 10mm.
Does 25mm mean: 25mm on a side, 25mm diameter hole, 25mm radius hole, or 25 sq mm hole.
Thanks.
Re: How is the Min Escape Hole defined? [message #72776 is a reply to message #72773 ] Wed, 07 August 2013 17:59 UTC Go to previous messageGo to next message
I would say diameter.
It is definitely not sq. mm as the dimension is mm.
Normally a hole is round: if it is a polygon I believe that would have been specified.
When we give dimensions for a hole we do not use radii but diameters - think drill bits (which create holes). The diameter is something which can be directly measured, a radius must be calculated in the real world.
Re: How is the Min Escape Hole defined? [message #72783 is a reply to message #72776 ] Wed, 07 August 2013 19:39 UTC Go to previous messageGo to next message
Thanks.
Of course, the easiest hole to create in 3D would be a triangular hole or quadrilateral hole by just deleting a polygon.and adding walls.
Re: How is the Min Escape Hole defined? [message #72790 is a reply to message #72783 ] Wed, 07 August 2013 21:08 UTC Go to previous message
That's true, but it would not make a very good looking aperture imo.
But if you wish to go that route, I would try for a similar area of hole as any of the specified combinations (although confusingly they don't add up to the same area).
Previous Topic:How to get started
Next Topic:I'm not sure I correctly understand "minimum detail size"
