Home » Support » 3D Design »
How to model interchangeable parts to make customizable 3d printed object
How to model interchangeable parts to make customizable 3d printed object [message #71986] Tue, 23 July 2013 12:09 UTC Go to next message
avatar guidosalimbeni  is currently offline guidosalimbeni
HI all,
I would like to ask you help regarding "How to model interchangeable parts to make customizable 3d printed object".
I'm looking to create a sort of LEGO character type of model , where usually , head , torso and leg are separated pieces that you can join toghether .
I understand that in this case the white plastic material is much advisable cause is strong enough to resist pressure and the final model needs to have an appropriate gap between parts of 0.5 mm.
My problem is that all the different alternatives of torso , leg and head , that can be picked to customize my model , are colored with different type of clothes , just painted on the plane surface of the model.
I understand the only material that supports color information is "sandstone", which unfortunately can break under pressure.
Can I work with sandstone to make this kind of LEGO project?
How much should be the gap in this case ?
Have you tried other solutions for a similar project?
Can you please send me a link to tutorial that can help me develop this project correctly?
thanks in advance I really appreciate your help.
Regards
Guido
http://www.guidosalimbeni.it
Re: How to model interchangeable parts to make customizable 3d printed object [message #71992 is a reply to message #71986 ] Tue, 23 July 2013 13:35 UTC Go to previous messageGo to next message
Hi Guido,
you could make the coloured pieces in Full Coloured Sandstone (FCS) and create connectors in WSF.
For example, you could print the ball part of the ball-and-socket joints as part of the coloured pieces and then the socket would be in wsf with a post to push fit into the next FCS piece.
Just an idea, I'll let you figure out the details...
Good luck!
Re: How to model interchangeable parts to make customizable 3d printed object [message #71995 is a reply to message #71992 ] Tue, 23 July 2013 13:45 UTC Go to previous messageGo to next message
Thankyou AmLachDesigns,
this is a great idea . I will investigate it.
So you agree that making all in sandstone it's likely not going to work, right?
Regards
Guido
Re: How to model interchangeable parts to make customizable 3d printed object [message #71997 is a reply to message #71995 ] Tue, 23 July 2013 14:06 UTC Go to previous messageGo to next message
"Sandstone" is simply not flexible at all, so you will either need connector pieces made in WSF, or glue the parts
together as in this figurine recently displayed in the "It arrived" forum.
Re: How to model interchangeable parts to make customizable 3d printed object [message #72000 is a reply to message #71995 ] Tue, 23 July 2013 14:21 UTC Go to previous messageGo to next message
Exactly.
Or, to put it another way, if you assemble an all FCS model with push-to-fit design you will end up with many more pieces than you started!
Re: How to model interchangeable parts to make customizable 3d printed object [message #72001 is a reply to message #71997 ] Tue, 23 July 2013 14:28 UTC Go to previous messageGo to next message
Hi mkroeker,
thankyou for your reply and the precious link.
it seems that the torso and leg has of the girl in the link has connector , like "push and fit" , is this the type your are mentioning , AmLachDesigns?
How to you thing the gab inbetween the torso and leg of the figure should be thick at the level of the connection?
regards
Guido
Re: How to model interchangeable parts to make customizable 3d printed object [message #72004 is a reply to message #72001 ] Tue, 23 July 2013 15:08 UTC Go to previous messageGo to next message
maybe I misunderstood your original post. Are you wanting to create models with interchangeable parts that are poseable? That will be taken apart and put together again in different combinations? Or do you just want a modular set of components from which you can create different models that once assembled will stay as they are?
Each of these scenarios has different challenges. For the last case you could use just FCS and glue the parts together.
Here is another link 61630 you might find interesting. It combines wsf and FCS.
Re: How to model interchangeable parts to make customizable 3d printed object [message #72005 is a reply to message #72004 ] Tue, 23 July 2013 15:15 UTC Go to previous messageGo to next message
Hi AmLachDesigns,
yes
I woudl like a modular set of components from which you can create different models that once assembled will stay as they are.
and the link you sent is really reach of information . I'm going it to read it carefully
thanks
Regards
Guido
Re: How to model interchangeable parts to make customizable 3d printed object [message #72010 is a reply to message #72005 ] Tue, 23 July 2013 16:20 UTC Go to previous message
Happy to be of help - next time I will try to read the posts I am replying to more carefully!
Previous Topic:3D printing competition
Next Topic:Building a Biplane in Full Colour
