latest ring and box with steel logo and keyring
latest ring and box with steel logo and keyring [message #70225] Fri, 21 June 2013 03:07 UTC Go to next message
avatar leorolph  is currently offline leorolph
another ring available on Etsy. comes in a nice box with steel logo and keyring.
https://www.etsy.com/listing/154525540/eight-greek-crosses-r ing-a-sterling
index.php?t=getfile&id=34799&private=0
index.php?t=getfile&id=34800&private=0
index.php?t=getfile&id=34801&private=0
index.php?t=getfile&id=34802&private=0
  • Attachment: IMG_4000.jpg
    (Size: 238.11KB, Downloaded 489 time(s))
  • Attachment: IMG_4003.jpg
    (Size: 254.95KB, Downloaded 489 time(s))
  • Attachment: IMG_4005.jpg
    (Size: 271.29KB, Downloaded 485 time(s))
  • Attachment: IMG_4007.jpg
    (Size: 289.67KB, Downloaded 484 time(s))
Re: latest ring and box with steel logo and keyring [message #70226 is a reply to message #70225 ] Fri, 21 June 2013 03:10 UTC Go to previous messageGo to next message
A quick question for anyone that can answer. Concerning the texture behind the crosses and infinity character, if I added a noise texture to the model in this area would it reduce the print lines and give a more even texture to print?
Re: latest ring and box with steel logo and keyring [message #70240 is a reply to message #70226 ] Fri, 21 June 2013 07:36 UTC Go to previous messageGo to next message
Yes, adding a texture is a common method for obscuring print lines.
Another option applicable here, if you wanted to do the work, would be to enamel this area.
Also, one other option I can think of would be to add a layer of polymer clay and bake it in to get something like this.
Patterns For CNC
Re: latest ring and box with steel logo and keyring [message #70249 is a reply to message #70240 ] Fri, 21 June 2013 11:02 UTC Go to previous messageGo to next message
thanks. usually i tarnish silver with bleach then pollish back the outer surfaces (image below) but with this ring I kinda like it all silver.
index.php?t=getfile&id=34818&private=0
Re: latest ring and box with steel logo and keyring [message #70255 is a reply to message #70225 ] Fri, 21 June 2013 13:02 UTC Go to previous messageGo to next message
Which finish did you order the ring in? Normally with rings I order in the standard finish, and use my dremel to polish as I wish. If you sell them well, you could probably find a jeweler that will give you better pricing than one piece at a time.
Re: latest ring and box with steel logo and keyring [message #70258 is a reply to message #70255 ] Fri, 21 June 2013 13:12 UTC Go to previous messageGo to next message
so far from many rings ordered, I have only had this one ring in polished silver, normally I use a tabletop polisher, dremel, sand paper, file and grinder. even with the polished ring the inside was not at all polished and took quite a bit of sanding and polishing to get nice... I was quite happy with the polishing done on the outside, though I did give it a bit extra.
Re: latest ring and box with steel logo and keyring [message #70259 is a reply to message #70225 ] Fri, 21 June 2013 13:14 UTC Go to previous messageGo to next message
Have you tried glossy yet? More price but hand polished.
Re: latest ring and box with steel logo and keyring [message #70260 is a reply to message #70259 ] Fri, 21 June 2013 13:18 UTC Go to previous messageGo to next message
no. Its a bit expensive for my selling price, and Im a bit nervous about loosing the detail. I can get it to a high polish myself... I kind of enjoy doing some work myself.
Re: latest ring and box with steel logo and keyring [message #70261 is a reply to message #70260 ] Fri, 21 June 2013 13:20 UTC Go to previous messageGo to next message
leorolph wrote on Fri, 21 June 2013 13:18
Very Happy I like that attitude!
Re: latest ring and box with steel logo and keyring [message #70262 is a reply to message #70261 ] Fri, 21 June 2013 13:33 UTC Go to previous messageGo to next message
I think so to... since starting 3d printing jewelry (background graphic design and multimedia) I now have a small jewelry making room and most the needed equipment to make it from scratch, just teaching myself, and picking up the skills... really enjoy getting my hands dirty.
Re: latest ring and box with steel logo and keyring [message #70263 is a reply to message #70249 ] Fri, 21 June 2013 13:36 UTC Go to previous messageGo to next message
That's funny you should mention that and put that image up being that I am currently experimenting with different types of patinating processes. I tried hard boiled egg, but it wasn't dark enough for my liking. I tried liver of sulfur and didn't like the midnight blue black color. So, just a little while ago I ordered a hydrochloric acid / tellurium based product that will definitely get it to the black that I'm interested in.
However, your black in this image is exactly what I want! Very Happy I knew of the bleaching method using sodium hypochlorite, but in the images that I saw for this method it seamed to be more a soft gray than black. Yet, your result looks great! How did you do that exactly? Very Happy
Patterns For CNC
Re: latest ring and box with steel logo and keyring [message #70264 is a reply to message #70263 ] Fri, 21 June 2013 13:45 UTC Go to previous messageGo to next message
normal, everyday cleaning bleach, it will go pretty much pitch black if left for long enough. Put your silver object in the bleach completely covered and leave it ... 5 mins will go medium gray, 10 - 15 min will get dark grey and so on.... the most I have done is about 30mins and it was pretty much black. Try for 5 or 10 mins first, give it a wash and if its not black enough you can just put it back in to darken further. I also find it will darken a bit more over the next few daya/weeks.
Re: latest ring and box with steel logo and keyring [message #70948 is a reply to message #70264 ] Thu, 04 July 2013 12:49 UTC Go to previous messageGo to next message
Thanks for the reply! Surprised
After making that post I immediately went down to the grocery store and picked up some concentrated Clorox bleach and dipped my ring in it for about 10 seconds and actually watched it develop a nice dark gray patina. Amazing results! Almost black like yours!
I don't think I'll be using any of the liver of surfer or the hydrochloric acid with tellurium for doing patinating since I really love the dark shade of gray to almost black I get from the concentrated Clorox bleach. I also love the bleach cuz the odors it gives off are nothing compared to the hydrochloric acid or the liver of sulfur odors.
It's a good thing I saw your image, cuz had I not seen that I don't think I would have tried bleach given that I thought it produced light shades of gray. Smile
Patterns For CNC
Re: latest ring and box with steel logo and keyring [message #70950 is a reply to message #70948 ] Thu, 04 July 2013 13:11 UTC Go to previous messageGo to next message
good to hear.
I have been using the bleach for a while now and have been fairly happy with the results but am now trying to get a piece really black and it just goes a sort of graphite black darkness and wont go any further, Im wondering if liver of sulfur gel would get it blacker.. have you tried the gel? I have heard the gel will get it quite black if left long enough.
Re: latest ring and box with steel logo and keyring [message #70952 is a reply to message #70950 ] Thu, 04 July 2013 13:27 UTC Go to previous messageGo to next message
Yes I have the gel. From what I saw with the one time that I used it, it did get very dark, but it had a kind of midnight blue shade that I didn't like and it still wasn't black, it was more like a very dark blue gray. About as dark as the bleach, but without the blue tint.
As for getting supper black, I think this stuff might be what you want. I have some but haven't tried it yet. It's supposed to get you the blackest black possible.
Patterns For CNC
Re: latest ring and box with steel logo and keyring [message #70954 is a reply to message #70952 ] Thu, 04 July 2013 13:48 UTC Go to previous messageGo to next message
Thanks, though don't like my chances of getting that Midas stuff delivered to Australia "Hazardous items cannot be shipped internationally.", and couldn't find any easily online here. Confused
Re: latest ring and box with steel logo and keyring [message #70984 is a reply to message #70954 ] Thu, 04 July 2013 17:29 UTC Go to previous messageGo to next message
How about this supplier? Here's the catalog page, item number three.
http://www.hoj.com.au/images/catalogue/70c937674c7c136cf04a4392b71ae6c0.jpg
Though I gave you the Rio Grande link, that's not what I purchased for myself. The product I got off either Amazon or eBay is actually the item number 3 in this catalog called Griffith Silver Black. The same formula is sold under a number of names since I guess no one has a patent on it.
I did find another place too in Australia. See the last page of this PDF, bottom right, Jax Silver Blackener. I looked up the MSDS and its the same chemical formula as the other blackening products.
Patterns For CNC
Re: latest ring and box with steel logo and keyring [message #71034 is a reply to message #70984 ] Fri, 05 July 2013 13:59 UTC Go to previous messageGo to next message
wow thanks!!... you seem to have done all the hard work for me Smile
Re: latest ring and box with steel logo and keyring [message #71036 is a reply to message #71034 ] Fri, 05 July 2013 14:11 UTC Go to previous messageGo to next message
Very Happy
Re: latest ring and box with steel logo and keyring [message #71889 is a reply to message #70225 ] Sat, 20 July 2013 02:12 UTC Go to previous messageGo to next message
Another extruded logo for placement on jewelry boxes, this time for the women's rings, it also being my official personal logo. I might infill the "R" with black or red or maybe polish back the top surface to a shiny metal finish. you can see some of my other creations and wips on facebook here
https://www.facebook.com/RolphJewelry
or on Etsy here
http://www.etsy.com/au/shop/CurryTree
index.php?t=getfile&id=36968&private=0
index.php?t=getfile&id=36969&private=0
  • Attachment: IMG_4114.jpg
    (Size: 484.49KB, Downloaded 214 time(s))
  • Attachment: IMG_4113.jpg
    (Size: 463.12KB, Downloaded 216 time(s))
Re: latest ring and box with steel logo and keyring [message #72485 is a reply to message #71889 ] Thu, 01 August 2013 13:13 UTC Go to previous message
A blackened version of the Eight Crosses Ring.. blackened with liver of sulfur gel.
index.php?t=getfile&id=37607&private=0
Previous Topic:Hollow steel plated ring, with and without post work.
Next Topic:iPhone 5 Ripple Case
