bonsai plant limb trimmer
icon3.gif  bonsai plant limb trimmer [message #70058] Tue, 18 June 2013 19:26 UTC Go to next message
avatar billJankeys  is currently offline billJankeys
Hi Guys. I need some help with a project of mine. I am trying to figure out how to get this thing to work better by making the pinching edges actually pinch harder. In the sketchup model I made, the two "cutting edges" actually fit perfectly together, but here they do not fit at all and it makes the thing useless. I still want to try again to get one that works, but I don't know how to correct the issue.
Do you all have any ideas?
  • Attachment: DSC_0002.JPG
    (Size: 2.66MB, Downloaded 112 time(s))
Re: bonsai plant limb trimmer [message #70076 is a reply to message #70058 ] Wed, 19 June 2013 01:57 UTC Go to previous messageGo to next message
The printing process is not perfect. Though it may work perfectly in Sketchup a little bit of clearance is needed to compensate for the printing inaccuracies. This happens to be a common problem that is pertinent to all manufacturing methods, not just 3D printing, and most high end CAD software have commands for automatically checking the clearances of parts in attempts to avoid the problem of not seeing interferences.
You need to check the clearance between the two parts, where they slide against each other. The cutting blades should be zero clearance, but everything else should have a little clearance so that they can slide against each other without binding.
If you need help with adjusting the clearance you can add your model as an attachment and one of us will be happy to add some clearance for you. Smile
Patterns For CNC
Re: bonsai plant limb trimmer [message #70097 is a reply to message #70076 ] Wed, 19 June 2013 13:25 UTC Go to previous messageGo to next message
avatar leorolph  is currently offline leorolph
for the cutting edges i would over compensate then sand/file them back to a snug fit. or for a better cutting edge leave an area to slot on a small razor blade.
Re: bonsai plant limb trimmer [message #70113 is a reply to message #70076 ] Wed, 19 June 2013 17:45 UTC Go to previous messageGo to next message
Yay!
Thank you James.
I have attached the relevant files. I appreciate your help.... I'm a bit green when it comes to 3d modeling still...
Re: bonsai plant limb trimmer [message #70123 is a reply to message #70113 ] Wed, 19 June 2013 20:38 UTC Go to previous messageGo to next message
You did a great job of modeling this up! Surprised
I'm not sure I'm following the operation though. Can you explain step by step how you'd like this to function?
My initial glance seems to indicate that once the male part is snapped into the female part it would then be very difficult to do anything with it after that point. In your image of the printed version I see that it jammed up just before snapping in fully. Or am I misinterpreting your drawings here and it works in some other way that I'm not understanding.
Explain to me how it works or how you'd like it to work and then I can use some software I have to look for interferences and then adjust the clearances.
Patterns For CNC
Re: bonsai plant limb trimmer [message #70141 is a reply to message #70076 ] Wed, 19 June 2013 23:40 UTC Go to previous messageGo to next message
The parts are touching top and bottom, see image.
You need to cut away to allow the part to fit properly.
index.php?t=getfile&id=34719&private=0
Re: bonsai plant limb trimmer [message #70356 is a reply to message #70141 ] Mon, 24 June 2013 00:50 UTC Go to previous messageGo to next message
Thanks so much or your help! I am going to give this a try. I had somehow overlooked that little flaw and with your help, I found it!
Re: bonsai plant limb trimmer [message #70357 is a reply to message #70123 ] Mon, 24 June 2013 00:53 UTC Go to previous messageGo to next message
You are correct in your interpretation of the intent for this design! It does indeed jam up right before it closes all the way. I was hoping to get it to sort of click shut with no gap whatsoever. I want it to be able to pinch very tightly with as much precision as is possible on tiny little pieces of semi resilient vegetation.
Does this help clarify your questions?
Thanks so much for your help! I admire your skill and appreciate your time.
Re: bonsai plant limb trimmer [message #70358 is a reply to message #70123 ] Mon, 24 June 2013 00:54 UTC Go to previous messageGo to next message
Re: bonsai plant limb trimmer [message #70435 is a reply to message #70123 ] Tue, 25 June 2013 01:27 UTC Go to previous message
by the way, I love your guys' work on the shop that links to your screen name.
Those DJ headphone cufflinks are really cool.
Where did you guys learn this stuff? I got my only training from the youtube videos and google sketch up tutorials....
Previous Topic:Minions
Next Topic:How do I fix this hole?
